Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
Posted on Jan 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stuck on black and white
I can only see the picture in black and white. I do not know how it got like that. It was in color earlier today. How do I fix this?
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 232 Answers
  • Posted on Jan 25, 2008
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
232
Questions
0
Helped
66261
Points
454
Hi, this is usually an indication of a shattered color wheel, the only way you can be certain is to take the set all apart and look at the color wheel, looks like a set of prism glass mounted on a fan shaft, if the shaft doesn`t spin or the prism glass comes apart the picture will be black & white, hope this helps, BMW Rider
How do i change the picture on my camera from coloured to black and white ?
You can select the color mode to Black and white to shoot images in black and white. If you have already captured the images in color, you can use a software in computer to change the color mode to black and white.
Thanks for understanding.
Please let me know if you require any clarifications.
I have a Kodak EasyShare M340 it was working fine earlier today but now when I turn it on the screen is black and when I take a picture it comes out black too, even with flash I can see the saved pics on...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
1helpful
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
3helpful
The color is all red.
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Black and white picture
you have the cables hooked up the wrong way
Bad color
Turn the color level all the way down and see if you have a good black and white picture. If your screen isnt black and white it should have a predominate tint to it. then turn the screen control for that color down to achieve the best black and white picture. then adjust your color level that should help.
Color vs. Black/White picture issues
If the trouble is black and white looseboard in CRYSTAL. Loose need to resolder.
7helpful
4answers
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
White balance problem
My experience is that in geneeral terms white balance of the C765 is almost perfect. The earlier C740 did have a purple color in the white areas. The pictures need most a light push on trigger to first set up all correct. If you do so it should be nice colored. Olympus own xD card is required to make panorama pictures. Several pictures can then be set together within the PC software Cameras
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
