20 Most Recent
Olympus Camedia C-765 Digital Camera Questions & Answers
Why won't my Olympus C765 take photos?
Strangely my C-765 has changed and takes picture on P and download to PC on green arrow before did both on green arrow,maybe others are having the same experience?
MPEG4
MPEG-4 is a graphics and video compression algorithm standard that is based on MPEG-1, MPEG-2 and Apple QuickTime technology. Wavelet-based MPEG-4 files are smaller than JPEG or QuickTime files, so they are designed to transmit video and images over a narrower bandwidth and can mix video with text, graphics and 2-D and 3-D animation layers.
I have an olympus c756 ultra zoom
Your camera card reader may be damaged.This happens when card is damaged one or some piece from previous card remained in memory slot. Please take to camera technician. This is a precision job.
How do I unprotect pics on a 0lympus c-765
As it was the camera that put the protection on ..You need to put the card into the camera..And ..UN-TICK each one to unprotect them...The idea of the protected photos is so you cant erase them when you format the card.
Upload pictures from olympus c-765
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or
Picasa.
Noise Reduction
This function reduces the noise that generated during long exposures. When shooting night scenes, shutter speeds become slower and noise tends to appear on images. When Noise Reduction is set to ON, the camera automatically reduces noise to produce clearer images. However, shooting time is approximately twice as long as usual.
Do you know how to remove the write protect from
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
