Kyocera Mita KM-2550 All-In-One Laser Printer Logo
Posted on Dec 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to set up newtwork scanning on our Kyocera KM 2550 multifunction machine and I can't find in the manual how to do it?
Anonymous
Level 3:
  • Master 622 Answers
  • Posted on Dec 22, 2009
Anonymous
Master
Level 3:
Answers
622
Questions
0
Helped
227388
Points
1525
Cool... ok here is what you do goto usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
  • sanjay_dater Jul 01, 2011
    I need the scan system f operation gides both setup and function kyocera mita km-2550
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1101
Points
Cant scan a document network printer kyocera km-2550
Kyocera KM-2560 multifunctional copier. Both cassette 1 and 2 are undetectable by the KM-2560.
Question edited for full 'make model (what it is)'.
Question moved to Kyocera.
Try a power reset. Remove cassettes. Pull mains plug for 2 full minutes. Reconnect. You should get a 'No Cassettes' message. Insert cassettes.
If that doesn't work, you will need Kyocera Service for this business machine. Some ideas in the link.
https://www.google.com/search?q=km+2560+not+detecting+cassettes
How do you install new e-mail addresses on scanner for kyocera km 2550
Open the browser on your computer, type the Ip address of the scanner on the address bar, the page of the scanner will open, under scan to email destination, you can add or remove accounts.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
1helpful
My kyocera km-2550 multifunctional copier has started showing a error message "call for service c6000" and a phone number in asterisks. kindly advice on what to do or if there any online help.
This is fuser unit error code, you can try to reset it might work, but if the erorr code came back then you need to change the fuser unit.
In order to reset this code: follow those steps
on the panel press 1087 1087
The screen will change to service mode
on the panel again press 163
now look at the screen and you will see Excute.
Select Excute and press the Start key.
The Machine will rebot or it will asks you to turn it off and on.
After the machine load again, it should be good, if the Error came back!! Then change the Fuser Unit.
We have a KM 2550 copier and I am trying to get a manual free that tells me how to register a PROGRAM key (one step) to scan documents. The process is long and complicated and I need to register just one...
Hey is a link to the Kyocera website that will allow you to get all the manuals for this model for free.
http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=13703&pcat=10564&rcid=10009&rscid=10028&x=21&y=5#bottom
Hope this helps.
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
How do i network my Kyocera 2550 to other computers
All the information you need to set up printing to the copier can be found in the below to machine operation guides. I provided links to the manufactures websites so you can download them.
Basic Operations Guide
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=13703&rid=13431
Advanced Operations guide
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=13703&rid=13430
Scanning set up can be found in the following guides.
Scan system operations guide (setup)
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=13703&rid=13433
Scan system operations guide (function)
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=13703&rid=13432
Let me know if you need more assistance or have any questions.
Shawn
2helpful
How to you set up a Kyocera KM 2550 to scan?
cool... ok here is what you do goto www.usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
2helpful
Can't print on Kyocera km-2550
I have an HP 1350 all in one printer/scanner. It was printing fine until I wanted to scan a document. I pressed the scan button and now its stuck there. I can't get it out of scanning. I tried turning it off, unpluging and replugging. Can you help me.
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
