1) Disconnect cable from negative battery terminal
2) Raise vehicle front and suitably and safely support.
3) Remove cover from starter wiring (small right angle-like black plastic cover).
3) Loosen large wiring harness (underneath starter) so that it can be moved out of the way.
4) Remove outer nut and wires from solenoid.
5) Remove outer nut and wires wires from starter.
6) Remove two (2) screws retaining plastic flywheel cover and cover.
You will need to do this - otherwise you will be unable to remove the
front bolt holding the starter to the engine block. This cover is a
small black plstic piece located where starter penertates the flywheel
cover.
7) Remove (2) bolts retaining starter to the engine block. One
is accessable towards the front of the starter/vehicile and the other
(long one) is towards the rear of the vehicle - just behind the frame
cross member.
8) Position starter so that if can be dropped down (flywheel gear part first).
9) Reverse the above instructions to install the new starter/solenoid
SOURCE: 1991 chevy lumina will hardly run
DTC - 22 Throttle position sensor error (signal low), is tps connected?
DTC - 23 Intake air temp sensor error (low temp indicated) check and make sure the sensor is connected
DTC - 43 Knock sensor error, ignore this for now, will not cause rich run.
DTC - 53 System voltage too high, check reference voltage from PCM, it should be around 4.5 Volts, this could be the cause of all your problems, the computer will need to replaced almost for sure.
SOURCE: replace starter motor on a 1992 Chevy Lumina LS
First make sure you have enough clearance to work on the vehicle you may need a jack or jack stands. Then make sure your tires are blocked and emergency brake is on then disconnect the battery. Theres two bolt securing the starter to the engine block and two wires running from the battery to the starter. take the wires off and when your ready reverse the steps........
SOURCE: 1998 Chevy Lumina won't start, replace the starter
If no power is getting to the starter replace the electrical ignition switch next
SOURCE: how to remove a starter on 1993 chevy lumina?
Support the car very securely first of all
Remove the negative cable from the battery
Remove the wires from the starter
Remove the two bolts from the starter going upward to the engine block
Wiggle the starter out
Reverse this proceedure to reinstall
