Goof information. Have you eliminated or proven the Onkyo as a cause by going direct to the projector? Try another Input and/or Output. It's best to know which component is broken and if it's limited to a specific subset of its function.
Settings are also indicated. Run through the video setup again. If it just stopped, what preceded it?
Sorry about the typo - I meant GOOD information. And good luck.
Forgive my denseness. Are you saying the DirectTV Box dosn't work with your projector even without the Onkyo in the mix? Would that not mean the problem is in either the DirectTV box or the projector and NOT the Onkyo?
Does any of this ring a bell?
If you connect a video component to a COMPONENT VIDEO IN, you must assign that input to an input selector. For example, if you connect your DVD player
to COMPONENT VIDEO IN 3, you must assign COMPONENT VIDEO IN 3 to the DVD input selector.
By default, the DVD input selector is assigned to COMPONENT VIDEO IN 1, and all of the other input selectors (i.e., VCR/DVR, CBL/SAT, GAME/TV, AUX 1,
AUX 2, TAPE, TUNER, CD, PHONO) are assigned to the “- - -” option.
If you’ve connected your TV to the AV receiver with a component video cable, you can set the AV receiver so that composite video and S-Video sources are upconverted (*) and output by the COMPONENT VIDEO OUT. You can set this for each input selector by selecting the “- - -” option.
DVD------------------------- IN1
VCR/DVR----------------- ---
CBL/SAT ----------------- ---
GAME/TV ---------------- ---
AUX1 ----------------------- ---
AUX2 ----------------------- ---
Yes, I've connected the DirecTV box directly to the projector with the same component cables that were originally connected to the Component Output ports of the Onkyo. I've also swithed connecting the DirecTV box to all of the other inputs (Game/TV, Satellite, DVD, Aux, etc...) on the Onkyo, and the problem is the same regardless of which input I use. I've also moved the Component Input cables from IN1 to IN2 to IN3, and reprogrammed the video settings for the input to reflect the changes - same problem.
Thanks for trying, but I'm not there yet.
No, the DirecTV box works with the projector when I connect the two directly to each other with the Component cables.
I got no video output from the DirecTV box when I connect DirecTV to the Onkyo receiver, which is connected to the projector. All 5 channels of audio works fine, but there is no video signal.
I've tried all combinations of hooking up DirecTV to the various inputs on the Onkyo - same issue. I've been able to confirm there is nothing wrong with the projetor, nothing wrong with the DircTV box, and nothing wrong with the Component cables I'm using. I've also gone through the same trouble-shooting with an XBox360 instead of the DirecTV box - same video problem.
