SOURCE: Vizio LCD Green Pixels
call tech support and send it back to them. it is a defective tv. im having the same issues
SOURCE: My LCD has green spots
i have the same problem in black color but its not my screen i belive its only in vista
SOURCE: Problem with the picture on my Vizio flat panel
a better solution is to replace the LVDS cables or just reseat them as the contractor stated it could be a motherboard but about 90% of the time it is actually the LVDS cables ohm load that puts toomuch load on the motherboard. the cheapest solution if out of warranty is buy an lvds cable and simply replace it if the issue still exist after the cable is replaced it will be a motherboard issue but any time you have red green or blue speckles on a vizio TV you should always swap the cable first since quite simply put it is the most common point of failure with that issue.
SOURCE: vizio 42 lcd gets large dark spot. it will go away
HI...
It's probably a loose flex cable inside. Look on the web and find someone near you
Have a service tech check it inside for you
SOURCE: I have a 2008, Vizio VO47L 47 in. LCD TV. When I
Faulty T-con board or mainboard (AKA tuner board)...the tapping would make me believe it to be the connection of the LCD panel to the T-con board that is causing the issue! This board is located on the top of the tv while looking down from the back. Replace it and you will be good to go!
Please rate if this helped :)
