20 Most Recent Samsung LN-T4661F 46 in. LCD HDTV Questions & Answers
My 46 inch samsung has a picture distortion, it's like it has a mirror image , how can i fix this?
Anthony, you did not list a model #. If you would it makes it eassier to determine what may have happened with your Samsung TV. An LCD would start with LN46----.I have had screen issues with some samsung product. As well as other makes of televisions that use Samsung 46 inch dislay lcd.
12/3/2018 1:26:19 AM • Samsung... • Answered on Dec 03, 2018
0answers
Samsung flatscreen turns on but screen does nothing. HELP please.
Check the internet. Most likely a series of cheap capacitors. Replace them all (the ones that match the culprit). ~.20 each US.
5/30/2017 3:01:14 AM • Samsung... • Answered on May 30, 2017
No audio output from speakers or jack
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
4/22/2017 11:57:50 AM • Samsung... • Answered on Apr 22, 2017
Right side of Samsung LN T4661F 46in LCD is blurry
hi this could be a tab/ribbon fault, there are ribbons attach to the screen at the top there's chips installed on them. when one is faulty they heat up and make the ribbon start to flex and move causing this fault, hope it helps regards shaun
5/16/2014 3:59:39 PM • Samsung... • Answered on May 16, 2014
Very slow to turn on and has small light spots all over screen
The first thing to look for are swollen capacitors on the power board.replace them if so.
4/13/2014 12:32:28 AM • Samsung... • Answered on Apr 13, 2014
0answers
2answers
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
7/27/2013 1:56:17 AM • Samsung... • Answered on Jul 27, 2013
How to repair tv with lines on display
the samsung LNt 4661F has been known to develope flex tab bond issues which will cause line to run across the screen and you can also gt darker bands that run across the screen when the tab bonds fail. usually flexing the screen frame or a light tapping will allow the lines to disappear when its warm if its a tab bond issue
4/24/2013 3:55:33 AM • Samsung... • Answered on Apr 24, 2013
The tv does not turn on right away, ther are clicking sounds before it comes on
It sounds like faulty capacitors inside the set, this model is known for this problem. Are you looking to repair yourself or just looking for a repair estimate?
3/28/2013 11:36:25 PM • Samsung... • Answered on Mar 28, 2013
Insignia 42 tv horizontal line problems
One among the back-light CCFL lamp has burned out. Replace it.
1/24/2013 3:58:19 AM • Samsung... • Answered on Jan 24, 2013
Samsung LN-T4661F 46 in. LCD HDTV Logo
138 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
samsung ln40a530p1fxza led light blinks
  • Televison & Video
