20 Most Recent Vizio GV42L 42 in. LCD Television Questions & Answers
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
Vizio GV42L 42... | Answered on Feb 22, 2019
Please check for bad electrolytic capacitors on both main board & power supply, if there is any "pup-up" one, replace it (them).
Vizio GV42L 42... | Answered on Aug 16, 2017
This is normal on vizios, ours does it too. You have it switched onto RGB input. You need to change input after it comes on. Switch on and keep pressing change input button till it changes and then it will be fine. Alternatively plug in a computer on Rgb and then turn on, you will be able to change input normally.
Vizio GV42L 42... | Answered on May 23, 2017
Remove the TV cabinet to expose the circuit boards and plug and unplug the connectors the main circuit board, that many times will fix the issue.
Vizio GV42L 42... | Answered on Apr 04, 2017
Hi I have Vizio e422va it's not turn on only front power light is on white when I plug power coward no led no screen is black please help
Vizio GV42L 42... | Answered on Jan 02, 2017
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Vizio GV42L 42... | Answered on Sep 02, 2016
maybe you have to bring your tv to repair center
Vizio GV42L 42... | Answered on Jul 18, 2016
Try to find new screen on amazon here Amazon com vizio 42 screen replacement. Hope this was helpful. cheers
Vizio GV42L 42... | Answered on Mar 20, 2016
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Vizio GV42L 42... | Answered on Feb 26, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Vizio GV42L 42... | Answered on Feb 14, 2016
Replace the main board. That board controls all the symptoms you're having. You can get the Vizo Main Board 3642-0182-0150 thats the board for your model from www.tvcircuitboards.com it has a 6 month warranty
Vizio GV42L 42... | Answered on Jan 25, 2016
Vizio GV42L 42... | Answered on Oct 31, 2015
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
Vizio GV42L 42... | Answered on Aug 30, 2015
The screen is the most expensive part of the whole TV, save money for new set.
Vizio GV42L 42... | Answered on Aug 27, 2015
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Vizio GV42L 42... | Answered on Aug 22, 2015
I looked up the manual for this TV and it has composite (RED, WHITE, YELLOW) and component (RED, GREEN, BLUE) connectors as well.
Are you using a cable or Dish box? If so, those boxes usually have output in Coax, Composite, and Component formats. You could just run that type of cable. If you use Component you will also need another cable set (RED, WHITE) for audio.
If, on the other hand, you do not have a cable box and you are using your TV's tuner you only have two options. You can repair the broken connector or you can route the Coax through an inexpensive VCR which will allow you to convert it to Composite cables. In this case, however, you'll have to use the tuner in the VCR, not the tuner in the TV to change the channel. Sorry it's not the best of news.
I want you to know that I'm not paid for this. It's a strange hobby I know, but I like to help when I can. While I cannot physically repair you TV, I hope you've found this information at least helpful and will rate it positively. If you have more questions please don't hesitate to ask. Thanks, and good luck.
Vizio GV42L 42... | Answered on Nov 14, 2014
Vizio GV42L 42 in. LCD Television Logo
624 questions posted
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
gv42l hdtv picture ok but no sound
  • Televison & Video
