Blinking lights when i turn it on the geen light flashes then the red light flashes and now the sleep light is flashing. so both the power light and the sleep light are both flashing at the same time. wheni turn the power button off the sleep light till falshes please help.
when i turn it on the geen light flashes then the red light flashes and now the sleep light is flashing. so both the power light and the sleep light are both flashing at the same time. wheni turn the power button off the sleep light till falshes. please, help me. thank you.
my e-mail: [email protected]when i turn it on the geen light flashes then the red light flashes and now the sleep light is flashing. so both the power light and the sleep light are both flashing at the same time. wheni turn the power button off the sleep light till falshes. please, help me. thank you.
I have exactly the same problem with the red and green lights flashing, tried to system reset and no differentI have exactly the same problem with the red and green lights flashing, tried to system reset and no different
You can't post conmments that contain an email address.
The red light flashing is indicating the error.
depending on the make and model of the TV, the duration of the flash and number of flashes determines the error code.
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Hi, Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair. Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info. Thanks.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are: 1) Green On, Red Off = Printer Ready. 2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up. 3) Green Fast-Flashing, Red Off = Printer off-line. 4) Green Slow-Flashing, Red Off = Processing Data. 5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing. 6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset. 7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted. 8) Green Off, Red Off = Printer power is off. 9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode. 10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
You have a bad power supply (AC adapter). Watch closely at the red light while turning tv on to see if red light momentarily flashes green, then back to red.
The flashing red light means that the tv is in protection mode. The tv will not turn on when the red LED is flashing. The most common problem for Hitachi are the convergence output ic's. But they useually do not cause the LED to flash. This tv does also have a problem with Q777 going bad. This will cause the LED to flash. If Q777 is bad the horizontal circuit needs to be modified. This must be done by a tech.
BLINKING RED LIGHTS
