20 Most Recent Proscan 19LA25Q 19 in. LCD Television Questions & Answers
Send the unit to manufacturer for replacement.
Proscan 19LA25Q... | Answered on Feb 10, 2018
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Proscan 19LA25Q... | Answered on Apr 21, 2017
Hi
Is there an "eject" button?
Proscan 19LA25Q... | Answered on Oct 03, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble and re-assemble procedure to many popular brand TVs and other devices are given with illustrations.
Proscan 19LA25Q... | Answered on Sep 09, 2015
The switching power supply is probably the problem. There is a 1000mF@25v capacitor in the P/S that goes bad from the excessive heat. Try another power supply or have your old one repaired.
Proscan 19LA25Q... | Answered on Aug 18, 2015
Hi Carl,
Attaching a stand to a TV is a very simple job. You have to put or slide the stand in to its slot and tighten a few screws. Please try it I am sure you will do it.
Proscan 19LA25Q... | Answered on Aug 05, 2015
Hi Ed,
Failed speakers is a common problem for no sound in flat panel TVs. Please have them checked before doing anything else.
Proscan 19LA25Q... | Answered on May 27, 2015
make sure speaker is on check menu settings but ti may need reseting go to www.proscanvideo.com for reset info.
Proscan 19LA25Q... | Answered on Feb 22, 2015
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Proscan 19LA25Q... | Answered on Sep 04, 2014
You have to make sure that the TV is not switched to CABLE in the settings, then run auto detect in the automatic channel set up.
Proscan 19LA25Q... | Answered on Oct 30, 2013
I bought two tvs and after about 3 months one of my tvs would not turn on; this tv was used more than the other one that is still working. I noticed that the power cord has a box that connects the two parts of the cords together, well the box gets very hot. I thought that the problem could be the power cord (may be it burned out) and not the tv. I switched power cords from the working tv to the nonworking tv and that sovled the problem.
Proscan 19LA25Q... | Answered on Jan 16, 2013
Proscan 19LA25Q 19 in. LCD Television Logo
159 questions posted
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
program channels checklist checklist
  • Televison & Video
