We need to replace the waste toner container on our canon imagerunner 330s.
1) where dose this waste container located in the machine?
2) where can we purchase the part?
open front cover, release developer lever at right,release feeder lever at down right corner,unscrew the centre screw at the top of the drum unit, slide out the drum unit, at the back of unit u will find a clear plastic cap remove it and empty the waste toner reverse all the process to place all togather.
The waste toner bottle is hidden behind the front cover of the machine. Just under where you fit the toner cartridge. If you are competant with a screwdriver, remove this cover and you will find the Waste container. The screws for the cover are hidden behind a rubber bung.
When you open the front cover,there is a transperant bottle with waste toner remove the bottle and remove the waste toner from the bottle.There is aslso a small clear transperant plastic holder that detect the level of the waste toner.Use a no2 star skrewdriver and remove it.Clean it and put it back.And reinstall the waste toner.
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Hello sir;The waste toner bottle right in front of the machine, when you open front door you ill see a white bottle remove and dump it out, turn power off and back on.
If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
sol:
1:you have to replace the drum unit.
or
2:open the drum unit & open waste toner cap &remove the waste toner & close the cap&insret the drum unit into m/c .problem solve.
