20 Most Recent
Canon imageRUNNER 4570 Copier Questions & Answers
E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
1/31/2022 7:39:21 PM •
Canon...
Answered
on Jan 31, 2022
E000075-0003
The E075 error code refers to the ITB belt shifting front to rear of the machine and can not compensate. There are two causes that will make this happen. a) The machine that is not level b) Uneven thickness of the ITB belt from front to rear. To resolve this issue, first observe the ITB Position value of displacement in service mode under Copier > Display > Misc > ITB-POS. The range is between -300 to +450. If the value is very close to the high end or low end, perform the following:a) Check to make sure that the machine is level.b) After leveling the machine, run Copier > Function > MISC-P > ITB-INT in service modec) Check Copier > Display > MISC > ITB-POS again to make sure the value is approximately within the mid ranged) If the value in step c is not within mid range, remove the ITB belt and reverse it from front to rear and repeat the prior steps again.This Should Only Be performed by a certified technician
4/14/2019 1:26:21 PM •
Canon...
Answered
on Apr 14, 2019
E000020-0000
This is a standard toner error code. This is a way for the copier to prevent the Developer Unit from being completely emptied of toner. Was the copier displaying to replace the toner cartridge? Remove the cartridge and see if it feels empty, if so replace the toner cartridge. The manual indicates that there is a blockage between the toner supply and the developer unit. I really don't think this is the case. This will really be a bear to fix if it is. The book doesn't indicate that the copier error has to be cleared in service mode. But this is the procedure ( for all the newer digital copiers ) if you need it. Depress the Additional Function key, then the 2 & 8 keys at the same time, and the additional function key again. This will display the service mode menu. Touch the Copier key. Across the top of the screen you should see " Function ". Touch it, look for CLEAR in the middle column. Touch it, then ERR, then OK. Turn off the copier and wait a few seconds then turn it back on and all should be well. After the initial reboot, you might hear the whirring on the toner motor trying to add the toner to the developer unit and this may take a little bit. Make several copies and make sure the copier doesn't error out again. If it does the then the supply tube maybe clogged and I don't think I could explain what is needed then. Hope this helps.
6/17/2018 11:39:08 AM •
Canon...
Answered
on Jun 17, 2018
E00000 70000
Easy fix. Go to http://www.manualowl. com
Click on Canon, click on model #
Go to PDF file, Index, Troubleshoot section of PDF
Jimmey176
11/19/2016 10:38:00 AM •
Canon...
Answered
on Nov 19, 2016
Error code e00001-0000
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
5/30/2014 3:02:26 AM •
Canon...
Answered
on May 30, 2014
How can i solve error e000001-0000?
select copier
select function
select "clear"
select "err"
select ok.
5/30/2014 2:33:57 AM •
Canon...
Answered
on May 30, 2014
