SanDisk Sansa  c200 MP3 Player Logo
Anonymous Posted on Jan 08, 2008
Only half of my music shows on a computer while the other half shows on another.
I started downloading music to my sansa c200 from limewire. There are all in winamp format. Then i went on my friend's computer and put some songs on but there were all in mp3 format and i was not able to to see the other songs. So when i plug my sansa on one computer, it only show the songs that are winamp or mp3 on my friends it never shows everything. What should i do. Would it be a good idea to change them all to mp3, if so how.
  • Anonymous Jan 09, 2008
    yea, the only the songs i put from my friends computer shows on his and vice versa
Anonymous
Level 2:
Novelist:
  • Expert 167 Answers
  • Posted on Jan 09, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
167
Questions
Helped
74203
Points
374
Install winamp on your friends computer and see if they show up.
Are you saying the songs don't show up on the actual device on when you connect it to the computer?
    But do all the songs appear on the actual device? Did you see if all the songs appear in winamp?
    What you could do is:
    1. search for all the audio files on your player (in step 2, you may want to type this instead *.mp3, *.wma, *.m4a, *.aac, *.wav)
    2. copy them all to your pc
    3. Format your player (or just remove everything)
    4. Use winamp or other program to transfer everything back to your player from your computer
    Sandisk provides "how-to" videos for
    everything Sansa related (instructions on how to transfer songs, format the player, etc)
    http://www.sandisk.com/Retail/Default.as...
    you may also want to consider updating the firmware
Lost the disk that came with my sansa c200 MP3 player.
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Can i download limewire on my sansa c250?
You will not be able to download Limewire to this device. You might be able to copy the installation file to it so you can install it on friend's computers and the like, but you will not be able to install it and download music from the device. You can, however, isntall Limewire on your computer, download music, and THEN transfer the music to the device.
SanDisk Sansa Clip
Use Windows Media Player to transfer the songs downloaded from Limewire to your Sansa. The first time you open Windows Media Player, it will search the "My Music" folder for songs - this may take a few minutes. Mkae sure you have Windows Media Player 10 or 11. You can either move or copy the Limewire songs to the folder called "My Music," or go into Windows Media Player and change Windows Media Player's configuration so that it can read the Limewire downloads folder.
-Tha Mp3 Doctor
Cannot upload music to my sansa c200
Try plugging in the player(turned off) before you turn on the computer.
Downloading music
do you have an installer of this software or you just downloaded from the internet?? try to reinstall the software and make sure its updated to improve the function of your software.
Goodluck!!!
1helpful
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
4answers
Cant load songs
Windows XP SP1
Intel Pentium class PC or higher
CD-ROM drive
TRANSFER MUSIC
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
My sansa e200
-Plug in your mp3 player
-Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
Sansa C200 Series -- Device Not Found
Sandisk provides "how-to" videos for everything Sansa related
You should check out the sansa community forums and post your issue, those folks know about EVERYTHING sansa and should be able to help you
Very helpful Sansa user Forum
Offical Sandisk Sansa user Forum
4answers
Can i use limewire?
step 1; down load songs from lime wire. step 2; go to lime wires library, and about half way down the page there is a button called explore. click on it. step 3; open windows media player, and click sync. a list should show up, step 4; click on songs on shared folder, and drag to sync list. step 5; connect sandisk, and click synk to e 250 on upper right hand corner area, and wait for sandisk to write! hope this helped!
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
