HP Pavilion ze4430us Notebook Logo
Posted on Jan 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blue screen with message to shut down.
Windows XP keep rebooting even after using original HP OS disk:
1. Setup....unable to set up as detected partition problem
2. R .... repaired buat still unable to restart
Hard disk makes grinding noise when running which goes away softer later.\
Do I need to replace the hard disk?
Thanks.
Len
Thomas Christopher
Level 3:
Genius:
  • Master 1,601 Answers
  • Posted on Jan 01, 2008
Thomas Christopher
Master
Level 3:
Genius:
Answers
1601
Questions
Helped
1052930
Points
3958
Sounds like it is just about gone to me...
  • Thomas Christopher
    Thomas Christopher Jan 04, 2008
    Please rerate this as a FIXYA, thanks
I turned on my modem, an all that is displayed on my monitor is the blue hp screen. In the botton left hand corner it says <F10=Setup> and <Esc = Boot Menu> and in the right bottom corner, it...
what modem, who's and where, ?
or is modem , monitor?
which blue HP screen there are many,
you left out what it says...
i can not watch you boot, and what is displayed, is key to the cause.
NO OS stated, is this XP?
when you boot, it always prompts in text ,hit ESC key to enter setup"
this is the BIOS hot key prompt that some times shows
a cute small HP icon this too is BIOS created.
then the PC boots and goes to OS, there many OS offered
Windows is XP is one? is it?
or Vista.,w7,/8/10 or PS/2 or linux. HP has many offered OS.
as do Refurb companies endless.
if windows?, the windows log in screen is next.
so my guess is the PC goes to BLUE screen that, before that.
stating (presenting)
startup file failed?
or , HP recover failed.?
or any of 50 other windows blue screens of *****.?
why not post a photo of the screen?
one screen is the XP BSOD , crash screen.
seen here.
one other blue screen is "windows is doing updates" so let it??
one modern HP W10 screen 1 of 50
this is most times below a bad video card driver used on PC.
not matching card to OS. and bam crash.
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
well that is so easy to answer,
first off you are not using real HP disks are you.
sure. its old Blue Microsoft disks right,
and when you do that wrong, you get no HP chip drivers and lost more missing, even top row, fn keys dead, not just audio.
XP is a dead OS. for 3 years now, zero updates and is now a virus magnet extream.
nx9010 note book shuts down, all 3 os install different. !
old XP runs a very old and very DUMBB seteup.,exe
the newer OS run WINPE for setup.exe. vastly better and boots and loads the OS totally different.
Xp can be installed many ways, not one stated by you.
1-insert, HP install disk in CDROM drive and click, setup.exe running in a XP explorer window, live install
2: boot to HP install disk.
3: boot and hit F11 run HPs on HDD restore partition.
4: same as a above 1, or 2, but is Micro soft disk (wrong, you did it wrong, do not use mS disk) if must ask how, its a long long long story. ive done it all ways, 1000s of time. now since first PC.s ever.
if booting to XP , right or wrong CD. (its a CD right<)> or a stick
that too not stated,
it boots and you answer questions, then it starts copying
if it stalls that means, the CD is bad.
or PC is bad, you do know there are 3million transistors here to fail right? bad HDD, bad Mobo, and more. lots more
even the CPU can over heat and will shut down.
Personally I avoid all CD nows, they sux'd then and do now more.
make and ISO of your CD, (ask its easy and free)
then burn the ISO to a 4GB or bigger uSB memory stick using free RUFUS app.
boot to stick. on my HP hit F9 and pick Udisk USB. boot
bingo no more CD errors ever again.
i bet bad CD. seen it vast times, endless , but not today. too savvy now. to mess with any CD, if you copy it to ISO and get CRC errors
its a bad CD.
end pain.
the problem with real old PC most cant boot to USB
or must be BIOS flashed updated to get that.
ill now ill try to learn what yours can or can not do.
lacking ,what is there now.
but id do this first. go in to BIOS BOOT PAGE
What is the default boot order? The default boot order settings for the computer are configured in the factory. The default boot order for HP notebook PCs is listed below.
  1. Floppy disk drive
  2. Optical drive (DVD, CD-ROM)
  3. Hard drive
  4. USB device (see this?) bingo, can boot and install any OS here
  5. Network adapter
4answers
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Shutting down at setup blue screen
even thoough it isn't the original cd that came with the the lapop it should still install.
make sure you clean the lens of the dvd drive with a damp q-tip of water and then gently clean it with a dry q-tip. This will ensure that the laser of the drive is nice and clean and free of dust or lint.
Then make sure there is no smudges of dirt or dust of on either sides of the cd so that way there can't be no write errors due to this.
Now see if you can install windows xp. If you still can't install windows xp then its because the hard drive is bad and needs to be replaced.
5helpful
3answers
HP 1000 mini-netbook bootmgr compressed--no cd/dvd hard drive--
Why all these clueless suggestions? I came here looking for help, but it appears I'll be solving my own problem and lend a hand. First attach something bootable via USB like you already know. Change boot order and boot from some kind of XP install disk. That's where I'm at right now. I'm now in the recovery console which gives me a command line. I had JUST READ somewhere the comand line commands to restore the boot manager that we just compressed.
Hold on....OK ! Problem fixed.
Step by step:
1)Get external CD reader and plug into USB
2)Boot Mini hit F10 or F12, whatever it says to change boot order
3)Reboot and you'll see you now have option to change boot order on bootup.
4)Boot to some kind of XP start disk(stupid me never even looked at HP's recovery disk yet - I didn't want to go there!)
5)Let the startup program run til it stops asking you to select an option, and hit R for recovery console
6)You'll want option 1 for c:/windows and type your password when asked
6)type fixboot then enter
7)It will happily inform you that your boot record is repaired
There may be some warnings or statements in between. You're desperate - agree to whatever they say! ;-)
8)reboot
9)Don't worry, be happy
If you can't stand that you now have that message booting up every time and it looks weird, RIGHT click my computer, properties, advanced, startup and recovery settings, and edit ....change default operating system from ** to Microsoft Windows XPHome etc."
click edit and for good measure delete where it has WINDOWS="" as an operating system. Don't mess with this if you're not sure.
10)Now be happy!
Can't reload windows xp. Keeps shutting down???? Acer 2700 Laptop
this happens when you have errors with the hard drive not responding to the new boot or drivers not responding. is this a clean install or a restore? if you are not using the original xp disk the machine came with you may get these errors. the blue screen usually has a message in it. let me know what it says if you get a second.
2answers
2answers
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
2answers
Windows XP not starting after power outage
I have just in fact a few days ago came across a similar issue. As to whether or not your hdd needs to be replaced is uncertain. What I can tell you is it seems as though the MBR or master boot record has become corrupt or one of the reader arms inside the hdd has failed.
Refering to the corrupted theory, may be simply fixed by booting off of a win xp cd and reformatting your drive and reinstalling windows after the format.
HOWEVER
In my case even booting off of a xp cd did not resolve the issue, every time anything would attempt to read from the hdd the computer would reboot. I suspected hdd failure at first, but this was not the case. It turns out it was a virus that infected the ntfs.sys and the MBR and put a binary code into those 2 files to reboot the machine.
Luckily at work (IT industry) I have a norton ghost server and was successfull at reimageing the hdd, doing so erases the MBR and everything else for that matter and rewrites it. However in doing so I lost all data that was on the hdd to begin with.
If you are not very tech savvy I would probably recommend hdd replacement however since you do have a HP which was prebuilt with xp, you don't have a xp install cd and thus unable to reload windows. I recommend finding a friend that has the xp install cd or you will have to go to the store and buy XP.
2answers
Blue Screen of Death
Just use ORIGINAL OS CD and repair OS everything will work fine!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
