20 Most Recent HP Mini 1000 Netbook Questions & Answers
Download delete system but it in CD boot on CD Then Format ur pc again
HP Mini 1000 ... | Answered on Jan 17, 2018
probably you are talking for bios and bios setting.
press start button and then press and hold Delete key.
HP Mini 1000 ... | Answered on Apr 06, 2015
you have to reset bios by disconnecting a small battery which is connected inside the laptop ...
How to open screen password laptop hp mini 210
HP Mini 1000 ... | Answered on Aug 11, 2014
If within Windows, there is software available on the internet for a price.
HP Mini 1000 ... | Answered on May 06, 2014
Hi I hope this we help you.
First check all programm menu and locate hp security folder in it you find recovery manager click on it and restored your computer to factory settings. if your computer has corrupted to the extent that the process stop then restart your computer at the process of booting strike on escape key on your keyboard to enter into series of procedure, which will indicate (f2, f9, f10, f12) with their respective actions strike on the function key that is set for recovery manager then follow the process. I believed this should resolve your issue.
HP Mini 1000 ... | Answered on May 01, 2014
There is no issue stated.
HP Mini 1000 ... | Answered on Nov 26, 2013
In the bios, set USB as first boot device.
HP Mini 1000 ... | Answered on Nov 19, 2013
Click on start, control panel, user accounts. When you get there, it's pretty much self explanatory.
HP Mini 1000 ... | Answered on Nov 04, 2013
how do i crack my laptop motherboard passwordof hp 110 minilaptop
HP Mini 1000 ... | Answered on Aug 03, 2013
password for ?
HP Mini 1000 ... | Answered on Apr 18, 2013
Use OPHCRACK. Google for it.
HP Mini 1000 ... | Answered on Apr 17, 2013
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
HP Mini 1000 ... | Answered on Feb 24, 2013
Did you try to remove de batrery on your motherboard ?
HP Mini 1000 ... | Answered on Jan 21, 2013
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
HP Mini 1000 ... | Answered on Jan 18, 2013
HP Mini 1000  Netbook Logo
157 questions posted
Popular Products
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Mini HP
  • Mini HP
Most Popular Question
reset bios password hp mini 110
  • Computers & Internet
