My samsung rear projection tv 2005 has multiple images with different colors. Its like the lamps are not merging into one image. This happened with just the blue color before but corrected itself after several days. This also corrected itself for a brief instance this morning but reverted back to the problem within 5 seconds.
The auto self focus screws up if the picture does not remain constant or close to it while focusing. It is designed to self focus every fifteen minutes. Go to menu and then setup and turn the auto focus feature off. I have had mine off for the past year and have had no problems. If you slide the bottom portion of the remote down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button during a scene and then hit the self focus button. It should align back up and may take a couple of tries. (If you have an aftermarket remote, just enter the menu and then setup and you can activate the self focus feature, just don't turn it to auto focus!)
My samsung rear projection tv 2005 has multiple images with different colors. Its like the lamps are not merging into one image. acts like red is out of alignment. has a red streak with double images at the left upper corner and double images at the rt lower corner. tv little over 3 years old. model # HC-P4752W cannot afford 400 $ repair bill any suggestions
My samsung rear projection tv 2005 has multiple images with different colors. Its like the lamps are not merging into one image. act like red projector out of alignment. red waves from lt top coner dipe down to mid center then back up to rt top coner like a red banner with double images and the rt lower corner splits out to double images. Foster kids miss the tv can not afford 500$ repair bill. mod # HC-P4752W any suggestion????
the colors aren't coming in correctly
the images are not focusing in properly
