E-Machines eMachines W2686 PC Desktop Logo
Posted on Oct 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound - E-Machines eMachines W2686 PC Desktop
Informat Enterprising
Level 2:
  • Expert 153 Answers
  • Posted on Apr 08, 2010
Expert
Level 2:
Answers
153
Questions
0
Helped
19795
Points
408
Try this steps: 1. click windows button bellow 2. click run 3. type dxdiag then hit enter. (dxdiag is a diagnostic test to find out if your sound system is working properly. 4. after you launch the dxdiag in your system and there will be a dialog box appear in your screen, just click YES button then your done then after clicking the YES button the dxdiag box appear in your screen. 5. wait while the dxdiag box loaded it jurisdiction as shown below the box. then when it's done just click the next page button below. 6. To know if your system has a sound. simply click the sound button on the upper side of the dxdiag box. then click the Test DirectSound. when you click the specified button there will be a dialog box again but just click yes to play the sound but take note you should have speaker or a headset to hear the sound. 7.For more (you can install a sound driver for back up). God bless and I hope this step will help you in your problem.
Anonymous
Level 3:
  • Master 1,959 Answers
  • Posted on Oct 25, 2009
Anonymous
Master
Level 3:
Answers
1959
Questions
Helped
1215937
Points
7500
Below is a link for the audio codec you need. Assuming all of your speakers are correctly installed, this codec will provide sound for your computer. Just download and install.
AC3 Codec
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
9helpful
2answers
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
Windows Media Player cannot play the file because there is a problem with
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
1helpful
3answers
My sound card is not working
look for the model number on the card and goto the manufactures website and download the driver
3helpful
Sound Quality Comparision
Slight difference.....The sound quality difference is observed.
You can find out the difference.In every motherboard on board sound is not so good.But in sound cards it is disigned specifically for sound.
if it helps
Pls RATE ME
14helpful
5answers
Free sound driver
i need creative sound card driwer
1helpful
SOUND DRIVERS
in your computer sound card problem. otherwise please check the control pannal in sounds and vedios.
then check the computer wheather the sound card installed or not. if the sound card not installed please installed the sound card drivers.
12helpful
10answers
NO SOUND ON MY COMPUTER
i need help put sound on my computer, and where to go to download a sound device driver
2helpful
2answers
No Windows Sounds or windows sound functions but All media players work
Select control panel >Sound and audio devices >select Sounds> Sound scheme options check whether the windows default theme is set. if not then set windows default theme.
thank you !
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
