I have a small ultrasonic cool mist humidifier from Walgreens. I think it is made by Sunbeam. When I turn it on, it makes bubbling sounds like it used to, and it makes mist, like it used to, but oddly, the mist does not ever rise out the top of the vent tube. There is nothing clogging the vent tube - you can look inside and see the mist in there, it just never comes out. When I take the water tank off the base, the accumulated mist kind of pours off the base.
Sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
