20 Most Recent
Sunbeam 701 Humidifier Questions & Answers
Working, but not blowing mist.
I think I found the problem.
unplug humidifer, remove top tank, empty all water out of base. dry off.
turn unit upside down.
unscrew five visible screws.
use a screw driver to pull off the black foam foot pads. you will find more screws there.
pull off the base.
look next to the fan, you will see a metal "tower" going up into the reservoir. Is it dirty such as white chalky substance on it? Clean it with cotton swabs. Clean the fan while your at it if needed.
You will see a small gray box with two metal tabs twisted. Untwist them and pull off the top.
On that metal "tower" you will see a small black chip connected to the circuit board where you just removed the metal top. Does black chip have black marks on the circuit board? Mine does. I suspect the "tower" which draws heat from this black chip was no longer able to cool because of the white chalk buildup on the tower, furthermore, the chip became too hot and caused the black chip to overheat (again black marks on the circuit board).
The chip has on it "FTR 02N" and a "54F" at the bottom. I tried doing some basic searching on internet to see if it could be replaced, but didn't find anything.
For those who don't have this problem yet, just keep that metal cooling tower clean.
We have a Sunbeam Cool Mist Ultrasonic Humidifier
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
How do I clean/sanitize my humidifier?
A solution of water and white vinegar will remove the mineral deposits built up from the water. Rinse "very" good, then wash out with a solution of 1 part bleach and 3 parts warm water.
Need the manual for Sunbeam humidifier swm2311
El manual de instrucciones del humidificador Sunbeam SWM2311 est? disponible para su descarga desde la p?gina web Sunbeam. Para descargar el manual del usuario, vaya a www.sunbeam.com/support/manuals y seleccione la opci?n "Humidificadores". Puedes encontrar el manual de instrucciones del Sunbeam SWM2311 en la lista de descargas disponibles
1/6/2023 2:32:03 AM •
Sunbeam...
Answered
on Jan 06, 2023
Sunbeam sul2512 humidifier leaking.
The Sunbeam SUL2512 Humidifier has three parts. From the top down:
Water tank
mist collar
Base unit
If the cap of the water tank (which contains a float valve) does not seal you may get excessive flow into the base unit which provides a working reservoir.
The base unit contains all the electronics including the cool mist transducer. This is a silver disk with a black silicone seal surrounding it. This is the only other place a leak can develop.
5/2/2018 9:35:34 PM •
Sunbeam...
Answered
on May 02, 2018
