Ovens Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My oven is a GE. I have it at set at 350 degrees
My oven is a GE. I have it at set at 350 degrees and it is showing that it is only at 325. It is a touch pad oven. How do you calibrate it to the right temperature. I have ruined lots of meals. Thanks,
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on Oct 20, 2009
Anonymous
Master
Level 3:
Answers
725
Questions
0
Helped
167378
Points
1617
You will have to change out your touch pad control to correct this problem. The same thing happened to my GE and I burned plenty of would be delcious meals before I finally replaced the board.
2answers
GE Profile PT916SM1SS will not heat up past 290
please check that the oven isn't leaking heat into another area. Or maybe your settings need some calibration or the temperature sensor for the oven is off by 60 degrees. If this is the case, changing the temperature setting to 410 should bring the internal temperature to 350 degrees. Please try this.
Thank you.
Nov 11, 2022 • GE Ovens
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Hardwick oven
replace the sensor in the oven as it tells the E R C ( clock) what the tempt is and the clock turns of the power . if this does not correct then replac the colck ..mm
Replace or fix a 10 year old JTP56 GE Profile double oven
The heating element is easy to replace and you can buy it online...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 • Ovens
1helpful
GE oven temperature is not true, and needs to be reset. Oven temp reads 350, but is actuallyonly 325. Can you help?
The temperature is within manufactures specifications.
By that I mean that the majority of manufactures allow a tolerance of + or - 10 % of the set temperature.
So, in your case, 10% of 350 degrees is 35 degrees, thereby showing that the actual temperature you are obtaining is well within the 10% allowance.
I hope this helps you .
2answers
Set oven for 350 and won't climb past 177. funny
The oven probably got switched from showing degrees Fahrenheit to degrees Celsius. (350 F = 177 C.) Try resetting that before you replace any parts.
4helpful
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 • Ovens
1helpful
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
