Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
Heather Knight
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 06, 2013
Heather Knight
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2569
Points
The only way I am able to get the PIP off my Sony Trinitron XBR is to use the buttons on the top of the TV itself. (I have the original remote that came with the TV and it does not work to turn off the PIP.)
On top of the TV set itself:
-First press the Setup button once
-Next press the TV/Video button until the PIP turns off. (Note: You may need to press the TV/Video button several times to scroll through a few different screens or it may disappear the first time you press it.) This combination works every time for me whether the PIP is turned on accidentally with the Comcast remote or the original Sony remote.
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Oct 20, 2009
Anonymous
Expert
Level 2:
Answers
83
Questions
Helped
27617
Points
207
Pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
  • jodi420 Nov 26, 2010
    um, whats DW key? i still cant figure this out!
  • Anonymous Feb 17, 2011
    A solution I found was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
mauriziosiac
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 01, 2013
mauriziosiac
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2700
Points
I was able to fix the problem by powering down the TV and then pressing the volume down key while powering it back on. The TV will cycle different PIP formats, just press the TV/Video button when you have the correct view.
3helpful
I have the 2000 Sony Trinitron model KV 27FS16 tv the picture in picture popped up on the screen cant get rid of it. I don't have the original remote anymore. Please Advise
Hello
To turn the PIP feature ON and OFF press the button marked PIP on the remote contro. Each press will get it vanished and reappear. OK.
2helpful
My tv is a sony xbr. somehow we got ourselves a black box (small) in the lower right hand corner. The remote doesn't have pip and we never used the pip. but i cannot get rid of this box. i tried to reset...
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
I have a Sony trinitron XBR and I can't get the PIP turned off.
8helpful
Sony Trinitron XBR TV, picture-in-picture got
2answers
I have a sony trinitron XBR and the PIP won't turn off. Any help is greatly appreciated.
Please make sure that one input is connected to the UHF/VHF port of the TV and other is connected to composite or component ports. If you have connected likewise, please perform the steps below:
  1. Ensure the video source is turned on.
  2. Ensure the video source is connected to an available VIDEO input jack on the back of the television. IMPORTANT: The VIDEO 5 input cannot be used to view a program in the PIP window.
  3. On the television remote control, press the TV FUNCTION button.
  4. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  5. If the issue is not resolved, connect the Audio/Video (A/V) cable from the video source to a different VIDEO input jack on the television.
  6. On the television remote control, in the PIP section, press the TV/VIDEO button to select the appropriate video input for the PIP window.
  7. If the issue is not resolved, replace the A/V cable.
6helpful
Pip pictture doesn t turn off
I had the same problem many times, and I don't have the original remote. Go into your menu options and select Auto-Program. It will run through all your channels, but when it is done, PIP will be off !! I have PIP!
TRINITRON XBR/ADVANCED 2 TUNER PIP Model KV32XBR45 Manufactured 1995
WELL I need some more information so I be able to assist you, first , it could be that the REMOTE CONTROL is not that came with the TV originally , and since all SONY remote control have the same basic codes ,it could be that the remote doesnt have this specific feature. I did some research base on the model of this TV , the original remote control model num. is RM-Y127 and
not RM-Y153 , maybe thats why it doesnt have the PIP feature. hope this info been helpful
2helpful
2answers
32 xbr vega trinitron PIP wont turn off
Just press any channel number and PIP will disappears :)
6helpful
2answers
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
23helpful
8answers
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
