20 Most Recent Sony KP-53XBR200 53" Rear Projection Television Questions & Answers
I have a KP-FX53M91 Projection TV. When I switch it on with the remote, the light turns green but changes to blinking red. I have to repeat more than 15 times before the Tv comes on. Lalit Sodha
yes your problem is the high voltage power supply , on this problem you would has to hire a tech to fix this problem , the problem is a voltage control ic who turn on the high voltage if this is not working properly the tv never come on or sometimes take forever , normal repair cost is about 200-250
8/17/2012 4:08:53 PM • Sony KP-53XBR200... • Answered on Aug 17, 2012
Xbr200 et xbr250
kp53xbr200 is too old for any real repair as a lot of the parts no longer exist.
4/30/2012 2:39:15 PM • Sony KP-53XBR200... • Answered on Apr 30, 2012
2answers
No powering up
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
4/16/2012 8:52:33 PM • Sony KP-53XBR200... • Answered on Apr 16, 2012
Sony kp 53xbr200 power light blinks 6 times and the screen is kinda flashing up and down.
This is a older set ( the blinks may at turn on be normal as set delays) and does the problem stop even for a brief time if you turn set off and right back on again?If no you may have to look for signs of Glycol---let me know and I will tell you where and what to look for.
3/13/2012 6:03:38 AM • Sony KP-53XBR200... • Answered on Mar 13, 2012
My sony tv stars blinking 5 times in a row, then
tv has a blanking picture mute circuit. adjust the screen controls which are located behind the speaker grill in front of set. there will be a access panel to unscrew in center and then you will see a black 4 inch square box with 6 physical knobs. 3 control screen the other 3 controls focus for red, green, blue. turn them down and slowly start turning them up. fixed.
11/15/2011 7:21:06 PM • Sony KP-53XBR200... • Answered on Nov 15, 2011
My colour is red and doubled (kind of 3D) but the
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2/21/2011 4:22:31 AM • Sony KP-53XBR200... • Answered on Feb 21, 2011
I have a Sony trinitron
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
2/17/2011 5:08:24 AM • Sony KP-53XBR200... • Answered on Feb 17, 2011
Colors are separated, double vision
Oh, yea - another misaligned projection TV. All rear projection TV's seem to eventually get this disease.
Fix: perform a "convergence," which will converge all 3 color projectors to the same point.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
1/2/2011 11:31:57 PM • Sony KP-53XBR200... • Answered on Jan 02, 2011
The picture is fuzzy, looks like 3D
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
12/22/2010 5:00:16 AM • Sony KP-53XBR200... • Answered on Dec 22, 2010
The tv looks like the old tvs with the contrast
Exactly as the old TV's. There is three tubes producing the picture and the technology is just the same. If you cannot find your instruction booklet, log onto Sony's web site and download it.
Hope this helps.
11/12/2010 9:31:19 PM • Sony KP-53XBR200... • Answered on Nov 12, 2010
My conversion is out of wack how do I re set it ?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
10/29/2010 5:58:36 AM • Sony KP-53XBR200... • Answered on Oct 29, 2010
The screen looks faded. The colors are right, but
take off the front of the set, and clean the lens as well as the mirrors inside the tv set
Techman
7/7/2010 3:10:21 PM • Sony KP-53XBR200... • Answered on Jul 07, 2010
Auto focus not working
Ur tv convergence are dead that why.The convergence board require the 2 STK convergence ICS and some or all it resistors must be change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
5/23/2010 2:12:33 AM • Sony KP-53XBR200... • Answered on May 23, 2010
I have a pip on my screen. Can't remove it
somw sets you need to set up in the set-up menu what signal source is shown in the pip box. to turn it off push the pip button on the remote once
5/17/2010 5:48:59 PM • Sony KP-53XBR200... • Answered on May 17, 2010
Fuzzy picture
have you taken off the screen and tried to clean the lens as well as the mirrors inside the set?
5/17/2010 5:46:23 PM • Sony KP-53XBR200... • Answered on May 17, 2010
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/18/2010 2:09:22 AM • Sony KP-53XBR200... • Answered on Apr 18, 2010
Center light out and alignment
Ur convergence is dead,U now how to solders?Tries Tv repair World.com,Tvrepairkits.com.
12/25/2009 4:59:31 AM • Sony KP-53XBR200... • Answered on Dec 25, 2009
Sony KP-53XBR200 53" Rear Projection Television Logo
49 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
colour red doubled kind 3d but
  • Televison & Video
