Apple AirPort Extreme Router Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is error code 4 for apple airport extreme wireless router
david willimes
Level 2:
Sergeant:
  • Expert 260 Answers
  • Posted on Nov 04, 2015
david willimes
Expert
Level 2:
Sergeant:
Answers
260
Questions
0
Helped
121026
Points
563
Download spotify again, without uninstalling your spotify.
Install the new spotify that you just have downloaded and it will automatic recognize you previous version.
Replace it and install.
Have fun.
for more help visit CBR Tech Solutions
1 Related Answer
Anonymous
  • 160 Answers
  • Posted on Aug 26, 2009
SOURCE: Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
2answers
I have a RCA Digital Broadband DHG535-2 modem but my Apple Airport Extreme router does not work, any ideas on how to resolve this issue?
Apple uses airport for its wireless connection, how ever the device where you want to connect to should have the wireless feature embeded to it or you should have a wireless router to distribute the wireless signal, if you are using just a modem which doesn't have capability of distributing wireless signals, the Apple airport will surely not work for it requires a modem to connect to. you need to get a router and connect it in your modem so the Apple will work for wireless as well.
3answers
Connected Airport Extreme wireless router unit to a PC. Airport Utility interface screen shows message: "Airport Utility unable to find Airport wireless devices...." Displays rescan button...
You may contact Windows Customer Service for any kind of help you require. You can also call on Microsoft Windows technical support phone number at +1-800-204-4427 and for UK customers the Toll free Number +44-800-046-5216 we are also provide technical support in AUS Toll free number is +61-1800-954-262.
1helpful
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
I have a Apple Router I know the Internet ID #, I know the Airport ID #, I have the Serial # but I cannot connect to my computer to go wirelee online. When I try to connect it requires a Password / Key...
Using your wired computer, you need to access the router's setup page by going to your internet browser and type http://10.0.1.1 and press enter, you can see the wireless network key under the wireless tab or wireless security tab
1helpful
2answers
I want ot disable DHCP on apple extreme router. Because MS 2008 SBS R2 scans for DHCP servers and fails to config if found an other dhcp server (apple extreme)
1) Open Airport Utility (Applications/Utilities).
2) Select the Airport Extreme in the left hand panel and press Manual Setup
3) Choose Internet in the top menu bar
4) Change Connection Sharing to 'Off' (Bridge Mode.
Press update to restart the Airport and save the settings.
4answers
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
