20 Most Recent Apple AirPort Extreme Router Questions & Answers
Download spotify again, without uninstalling your spotify.
Install the new spotify that you just have downloaded and it will automatic recognize you previous version.
Replace it and install.
Have fun.
for more help visit CBR Tech Solutions
Apple AirPort... | Answered on Oct 26, 2018
These instructions may help you
http://support.apple.com/kb/TS1589
Apple AirPort... | Answered on Oct 12, 2018
Try a reset of the Airport, or replace the internal circle battery, then reset. But sounds like the internal battery.
Apple AirPort... | Answered on Oct 01, 2018
1) Open Airport Utility (Applications/Utilities).
2) Select the Airport Extreme in the left hand panel and press Manual Setup
3) Choose Internet in the top menu bar
4) Change Connection Sharing to 'Off' (Bridge Mode.
Press update to restart the Airport and save the settings.
Apple AirPort... | Answered on Sep 21, 2018
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
Apple AirPort... | Answered on Aug 28, 2018
You may contact Windows Customer Service for any kind of help you require. You can also call on Microsoft Windows technical support phone number at +1-800-204-4427 and for UK customers the Toll free Number +44-800-046-5216 we are also provide technical support in AUS Toll free number is +61-1800-954-262.
Apple AirPort... | Answered on Dec 25, 2017
First, I would suspect your PC has the printer installed using the IP address of the printer. I would uninstall the printer, then go to "add printer" then "add network printer" and see if this works. If not: HP has a neat setup available for their printers. Go to their website and look for network printer setup. This will install on your computer, and go through your network and find your printer.
Apple AirPort... | Answered on Dec 01, 2017
try reboot of router if it doesnt replace router it has failed
Apple AirPort... | Answered on Apr 24, 2017
Find and check a wireless network label or sticker on your laptop. The Wi-Fi standard is written there. It indicates which capability your wireless card has.
  • 802.11b/g/n (or "bgn") --> your card supports 2.4 GHz band only. There is no way to activate 5 GHz without you buy new "Wi-Fi stick" having 5 GHz support.
  • 802.11a/b/g/n (or "abgn" or "abg") or 802.11ac --> your card is 5 GHz capable. Only laptop card setting change should be needed to enable 5 GHz radio.
The "a" means the 5 GHz.
For wireless standard logo types see a picture on this link:
Wireless Ethernet 820 11a To 820 11g Network Basics Networking Basics LAN...
Use any dual-band cell phone (Samsung Galaxy S4, S5, S6...) and free WiFi Analyzer Android application to check your router is transmitting 5 GHz too (channels 34 and higher).
Apple AirPort... | Answered on Jan 18, 2016
Open the airport utility:
AirPort Utility
Select edit
23347960-sxhmffcsgmnqgotfulreid1h-5-2.png Select advanced
23347960-sxhmffcsgmnqgotfulreid1h-5-5.png Select wifi settings
Select radio channel
Apple AirPort... | Answered on Aug 18, 2015
It means there is something wrong with the configuration.
Use the the apple airport utility to find out what is wrong.
AirPort Utility
Use this article to troubleshoot your issue. http://support.apple.com/kb/TS1589
Apple AirPort... | Answered on Nov 10, 2014
The Network Security Key is possibly the same pw as the network you are attaching to. This device can be configured in so many different ways.
If you can't figure it out then use the reset button on the back or use paper clip in reset hole.
To set up and configure your AirPort Extreme to use AirPort for wireless networking and Internet access, use the setup assistant in AirPort Utility.
The manual may be of some help... Available here
http://support.apple.com/manuals/#airport
Good Luck
Trevor
Apple AirPort... | Answered on Sep 16, 2014
  • Now, that is the serial #
Apple AirPort... | Answered on Aug 30, 2014
use your airport utility, it will guide you thour the setuo, remember, gate way or bridge. you need both, but you need to choice witch one.
Apple AirPort... | Answered on Jan 21, 2014
You need to default to your router, other wise looking for any network it can find.
Is your A P E a hidden network?, if so just type in the name of your router name and scan, it will find and ask for a password
make sure power is on, get a sharp instument, pen, pencel, what ever fits, push in for 30 sec, see the light change, and your good to go.
just power off, someone or thing, device is taking that ip in use, raise your ip range.
download Airport utility, works on all macs
Apple AirPort Extreme Router Logo
101 questions posted
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Computers & Internet
Most Popular Question
son macbook titanium gets great
  • Computers & Internet
