Very low hot water pressure in moen kitchen faucet model 7560C lever handle single control faucet with pullout spray. cold water pressure is okay. All other hot water faucets have good water pressure.
This is fun, you probably have some rust or lime build up in faucet, most of these single handles you have to remove handle setscrew usually small allen wrench. shut off water supply first!!! next the barrel should be held on by a screw remove and lift barrel out you should now be able to see build up clean and reassemble if you are not confident with this call a plumber good luck
