Samsung LN-T4053H 40 in. LCD Television Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung LCD Screen powers up for 1 minute then goes black.
Samsung LCD Screen powers up for 1 minute then the screen goes black. Other times the screen will power up and work fine all day but as soon as you turn it off then on the screen will stay on for a minute then go black. What would be causing this?
Jack South
Level 2:
Scholar:
  • Expert 195 Answers
  • Posted on Oct 10, 2009
Jack South
Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
35568
Points
350
Most likley there are some bad capacitors that need to be replaced in the power supply, in particular the ones that are "10 volt" types. As a tech...I LOVE to see these sets and or//power supply boards come in as it is "easy and quick money for me" and a quick and lasting repair for the customer. A decent shop should be able to repair your PS board for under 350, in home service.
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Black Screen
There are several things that could cause this. You could have a faulty backlight inverter(s), faulty 24V output from the power supply, failing backlight bulb(s), high voltage arcing from the inverter outputs, or a fault with the main board. I would recommend a diagnosis
2answers
TV will only stay powered up around 30 minutes. After 30 minutes tv will only powqer back up after a 30 minute or so cooling period. When tv powers off light goes amber just as though it were physically...
Power supply board have intermitten problems,not sustancenig a constance power to the tv.The tv power up 30 mins within the time frame,the tv work than,yes?The power supply board,that the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
3helpful
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
My Samsung LCD TV takes 1 minute to turn on with purple spots
could be the power supply board (most likely) or the main board.
Monitor goes black
Kindly attach the screen to your another system or note pc. Else being a simple device it contains only three main parts.
1) Panel
2) Power supply + HVPS
3) Main board
need to be tested one by one.
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Samsung 40" 1080P power flux
Try to replace the Power Supply board first.
6helpful
5answers
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
