20 Most Recent Samsung LN-T4053H 40 in. LCD Television Questions & Answers
I have a samsung ln-t4053h that had a bad caps. I
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
4/23/2017 1:38:09 PM • Samsung... • Answered on Apr 23, 2017
When started, why are vertical color bars showing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
11/27/2015 5:35:17 AM • Samsung... • Answered on Nov 27, 2015
0answers
Wont turn on
Be the first to answer 11/5/2013 4:32:35 PM • Samsung... • Posted on Nov 05, 2013Be the first to answer
Hello i got the same problem , but after changing almost everything also the eeprom ,its still don't work still going on and off but this time without clicking noise
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 800 posts to different brand TVs now. A factory reset must be done.
9/22/2012 4:52:54 AM • Samsung... • Answered on Sep 22, 2012
Clicks and clicks but wont
Hi.
The TV is in forced standby because an internal fault has been detected. The clicking is the protection circuit that prevents the TV from starting to avoid more damage to internal parts.
You can try disconnecting power cord for ten minutes but I doubt that this will fix the problem. When the TV is in protect mode (that is the name for the "clicking and no power on") repair is usually needed. Testing will start from PSU to inverter passing through main controller board. One of the most common faults affecting this TV is the power supply, but all parts must be tested.
If you want to call a technician ring your local Samsung Support number.
Regards.
Ginko
9/6/2011 4:31:12 PM • Samsung... • Answered on Sep 06, 2011
Trying to find another way to get over the air
I know some things that can help...you should have a nice digital air tuner in yours...(my girlfriend has nearly the same identical TV, but larger)...anyway, first time I had it 'search' for channels, I accidentally let it tune both Air + Cable, and was surprised when it came up with as many channels over-the-air digital as my own TV did WITH digital air antenna! So, you can scan for both. Secondly, try this site--www.tvfool.com--no kidding, it lets you enter your zip code and antenna height, and it'll give you the various channels you might expect to receive, PLUS what kind of antenna(s) you'd have to buy to get the various types (that's right--'surprise', there are different types of digital signals, jeez)... Finally, go to 'www.monoprice.com' and buy one of their cheap-o (you'd think) but highly-valuable and quality digital air antennas (link at bottom of this post), or the RCA ANT751 antenna, or another good digital air antenna, and you'll have the best outfit you could hope for (unless you still have your old tower, and can put a good one, or larger one, on it!)... That Monoprice 'generic' digital air antenna is the exact same one as you'd pay $60+ for at Radio Shack (I've bought both--I know).... Happy Viewing! that link to buy the Monoprice antenna: >>click here
7/5/2011 4:58:21 AM • Samsung... • Answered on Jul 05, 2011
I have a Samsung LNT4053HX.
U have a small power surge somewhere.Disconnect all connections to the tv and unplug the tv and replug it back like about an hour later.Reconnected all connections.Go into the the tv Sound Setting to do a resetting of the sound setting back to the factory reset.The tv sound should work find now.If still have the same problems,then the main tv Tuner signal board it is shorted and have intermitten dying parts on the tv Tuner signal board.Only choice now is tries buy a refurbish tv Tuner signal board for the replcement.Tries websites like Shopjimmy.com,Ebay.com to buy LCD tvs refurbishes pcb boards.
5/27/2011 5:14:01 PM • Samsung... • Answered on May 27, 2011
Samsung LN t4053 H.
Samsung LN-T4053H:
If this set is under warranty you should return it to get it repaired/replaced by the seller. If not then; This sounds like the power supply board could be failing. The electrolytic capacitors on the board may need to be replaced. It may also be a voltage regulator. IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(soldering ) or have a friend with knowledge/skill you can fix it. >Unplug the set and any cables. >Remove the back cover. The power connects directly to the power supply board. >look at the capacitors on the power supply board. If the top of any of them are bulging up then that is the problem. >You will have to replace ALL the electrolytic capacitors except for perhaps the large one. >Disconnect and remove the power supply board. Handle by the edges to prevent contaminates and static electricity.> Use ones with the Low Equivalent Series Resistance ESR rating> Use ones with the same farad rating > Use ones with the same or higher voltage rating> Use ones with high temperature rating> Install one at a time to prevent mix-up and keep the polarity correct. > Leave a space between the PC board and the bottom of the capacitors for expansion. They heat up.> Replace power supply board and reconnect cables..> Replace back cover. THIS IS AN INDUSTRY WIDE PROBLEM AFFECTING MANY COMPANIES AND PRODUCTS. Sources for some good capacitors are www.digikey.com or NTE. Try nteinc.com for a local outlet of NTE products.You can also search for other sources. Some companies even sell all the capacitors in a kit. Total price of parts should be < $30.00
Yes you can buy a new power board but if the capacitors have not been replaced they will eventually fail also.
3/13/2011 7:55:41 PM • Samsung... • Answered on Mar 13, 2011
I just bought a Samsun
is that the av channel? if so, how do you know your getting a signal from the ps3? try hooking the ps3 up to something else to make sure you have a signal coming out of that cable (this is where you have to start) if you have another device like a DVD player, or VCR, hook that up to the AV input (or channel one as you say). if you get a picture from those devices, the problem is your ps3 not sending the signals to the tv. sorry I can't be more helpful, but that's my guess
3/11/2011 11:05:53 PM • Samsung... • Answered on Mar 11, 2011
2answers
If you changed only the bulging capacitors, Try changing some more around those. They might be partially damaged already with out external signs. I replace all the PSU capacitors to solve this problem.
3/10/2011 7:30:47 PM • Samsung... • Answered on Mar 10, 2011
Picked up used LN-T4053H, hooked it up to cable
Did you set the ON SCREEN TUNER setup tuner to pick up from the signal from cable?
Did you download the user manul from SAMSUNG web site?
3/1/2011 11:45:26 PM • Samsung... • Answered on Mar 01, 2011
Samsung LN-T4053H---No signal
Here is the check list;
Go into the menu to verify the signal source is correct.
Try it on other channels.
Check the connections.
Check the source.
If cable, is it working, bill paid etc.
If antenna and it is amplified, has it failed.
2/8/2011 8:51:04 PM • Samsung... • Answered on Feb 08, 2011
I have to hit the power button a few times then it
It's possible that it is not the power supply though the odds point to it. did you notice if the tops of some of the caps felt rounded? They should be flat. this link Samsung Lawsuit is to an article covering the cap issue and the start of class action by a law firm who is currently taking consumer info to strengthen their case.
1/31/2011 5:47:42 PM • Samsung... • Answered on Jan 31, 2011
Everytime we turn on our tv, all we hear is a
Something is failing, albeit slowly. By hearing only a click does that mean the sound is dead too? Regardless, you most definitely have a hardware issue.
Get it repaired sooner than later. I am happy to assist you further if you are doing this yourself. I don't recommend it if you are inexperienced with electronics and high voltages.
1/6/2011 3:33:31 AM • Samsung... • Answered on Jan 06, 2011
2answers
My Samsung LCD tv clicks over and over again but won't power on
this is common fault the capacitors have blown on main power board you can replace your self if got soldering iron
take back off tv and look for capacitors that have RAISED TOPS they look like little batteries with white line on one side and numbers (e.g 2000mf 25v ) the best way to remember which way they go back is take picture
you can get parts from charles hyde and sons web site (CHS) under general components or at a electronic shop
5/31/2010 4:34:58 PM • Samsung... • Answered on May 31, 2010
No picture problem only sound comes
Hi, I am having the same problem with the same model.. if you figure it out can you please e-mail me [email protected]
Thank you!
5/24/2010 11:29:08 PM • Samsung... • Answered on May 24, 2010
My hdmi inputs says not supported mode on my
Not all HDMI standards are the same, some units will NOT work with some sets, sometimes you can get Software upgrades to make some work. You would have to check that out with the manufacturers of your equipment.
2/21/2010 2:34:20 AM • Samsung... • Answered on Feb 21, 2010
Samsung LN-T4053H 40 in. LCD Television Logo
43 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
just bought samsun
  • Televison & Video
