If you have aaccess to the belt already,
start the machine let it fill
then keeping an eye on the motor and the clutch underneath it, sounds like your clutch might be slipping..
you will notice immediately the motor will be spinnging but the clutch will not engage
ive included the part number
and phone number to call
AP2045377
1-800-477-7278
aplliancepartspros.com
runs about 120.00
but its a pretty easy repair especailly since you figured out how to open the cabinet
if you can freely spin the motor it is your start winding on the motor
you can confirm this as well
start the mchine while humming
try to spin the belt
if the machine takes over its your start winding
depending on the model
you may have a start capacitor
if you can check that on your meter before replacing the motor
SOURCE: WILL NOT AGITATE, SPIN OR
Open the back cover and start the washing cycle. When the agitator cycle begins check if the motor rotates. If it does not and the humming sound comes there is problem is withe motor. Also check the tightness of the belt. Even if it is loose it does move but it is slippery movement unless it is completely loose. Anyway the problem is with your motor and the connecting bearing/pulley. You have to ask a technicians to help you out
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Motor is not spinning, just making a humming noise.
