20 Most Recent Maytag Atlantis MAV6451 Top Load Washer Questions & Answers
Washer will drain & fill at the same time
Sounds like your timer is bad.
2/11/2021 2:32:21 AM • Maytag Atlantis... • Answered on Feb 11, 2021
I have a Maytag Atlantis MAV6200AWW. The washer
hi the solenoid on the cold water is gone down or it is not fed with electric
1/30/2018 12:14:28 AM • Maytag Atlantis... • Answered on Jan 30, 2018
0answers
As soon as i turn my washer on it just makes a loud grinding kinda noise how do i fix?
If the machine was delivered new, has all the transit straps been removed ? If the machine was delivered without transit straps then the drum could be off a support and it's drum wheel could be grinding on the rear panel.
10/4/2014 11:02:51 AM • Maytag Atlantis... • Answered on Oct 04, 2014
Lid switch
In my experience a washer drains by reversing the motor, which activates a switch to open a solenoid valve in the drain line. Your solenoid or the switch way be bad
4/1/2014 10:33:14 AM • Maytag Atlantis... • Answered on Apr 01, 2014
0answers
Washer will not agitate without a grinding noise
Check bottom pulley is fitted correctly & fitted with he right tolerances, check pump bearings. If all these are ok then gearbox needs replacing.
12/21/2013 2:52:00 AM • Maytag Atlantis... • Answered on Dec 21, 2013
Maytag mav-1 doent spin
What does it do when it gets to the spin cycle?
11/30/2012 10:15:51 AM • Maytag Atlantis... • Answered on Nov 30, 2012
Grinding noise when washing
Remove the back lower left access panel. Run the machine if you can to see if the noise is from the drain pump. This model is known for a bad pump design and has an updated design. Here is the pump to order. Remove the 2 hoses and the 3 bolts to remove.The part comes with a 365 day, any part, any reason return policy.
11/11/2012 6:51:20 PM • Maytag Atlantis... • Answered on Nov 11, 2012
Washer does not spin
Belt from motor to basket may be broken.
8/25/2012 3:52:33 AM • Maytag Atlantis... • Answered on Aug 25, 2012
Washer spins but does not drain properly
there should be a black hose going into your wall or floor for draining take that out and see if it is plugged
8/25/2012 3:26:29 AM • Maytag Atlantis... • Answered on Aug 25, 2012
Maytag Atlantis MAV6451 Top Load Washer Logo
317 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag atlantis cycles but
  • Washing Machines
