Hi, I'm from Brazil and I own a LG RD-JT91 projector. When I turn it on, after few minutes, a vertical white strip appears. What is wrong with my projector? Thanks for your help, Fabiano.
When I turn my projector on, the LG logo appears, but then nothing happens afterWhen I turn my projector on, the LG logo appears, but then nothing happens after
You can't post conmments that contain an email address.
IF it happens right away, it could be serious. If it happens when it is on for a while, you might need to clean out the dust buildup so the bulb can breathe.
There is basically two ways to reset the lamp timer :
1. ) On the Projector's physical buttons
Arrow Keys - Up , Down , Left , Right then Menu and Enter - this should be done quickly whilst the Projector is in standby mode.
2.) Switch Projector on - Hold in the Up Arrow Key on the physical buttons on the Projector untill a PIP screen appears - then just follow the on screen steps.
On the left hand side where all the inputs are located you will see a very small screw , that is most probably what's keeping you from opening it.
Also remember to take off the cover to the front and do this slowly because the translation board's lint is attached to the top cover. Once open you can just unhook it and then you'll be looking for the board with the AC inlet on it.
1-check the counter reading of lamp to see if it is in the right age of lamp or not.if it is in right age the problem still in power unit or in ballast.
