Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
Hilary Snow-Chase Posted on Sep 27, 2009
Is there a remote control code for model zv427mg9?
Is there a remote control code for DVD Recorder / VCR combo, model zv427mg9? I am trying to program an one for all universal remote.
Bryan P Atkisson
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 24, 2016
Bryan P Atkisson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3394
Points
  • 20675 Yes thank you Clint
Clint k
Level 1:
New Friend:
  • Posted on Feb 08, 2015
Clint k
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3394
Points
For my direct tv remote, 20675 worked for me :) magnavox zv427mg9 combo vcr, dvd
5 Related Answers
A
Anonymous
  • Posted on Jul 05, 2008
SOURCE: Philips Universal Remote with Emerson VCR/DVD Combo
http://www.urc.philips.com/
US2-PM335
There you will find all needed information
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Feb 15, 2009
SOURCE: need a code for a magnavox dvd/vcr com for a jumbo universal remo
7-1-1 and 0-7-1-1 are the Magnavox universals.
snakehead
Henry Thomas
  • 1074 Answers
  • Posted on Jun 04, 2007
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
epik559
Erik Garcia
  • 44 Answers
  • Posted on Nov 25, 2007
SOURCE: finding a code
Look under Funai with dish network.
ed_woj
  • 9 Answers
  • Posted on Jan 06, 2008
SOURCE: need remote control code
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
2answers
I have a Magnavox clo358 universal remote what are the codes for my Magnavox DVD VCR combo
To program your Magnavox DVD VCR combo using the Magnavox CLO358 universal remote, you can try the following codes:
0503
0675
1153
1203
1321
Here's how you can program the remote:
Turn on your Magnavox DVD VCR combo manually.
Press and hold the "Code Search" button on the remote until the indicator light turns on.
Release the "Code Search" button.
Press and release the mode button for the device you want to program (in this case, the DVD VCR combo). The indicator light should remain on.
Enter one of the codes listed above using the numeric keypad on the remote. The indicator light should turn off after entering the code.
Aim the remote at the DVD VCR combo and press the "Power" button. If the device turns off, the code is correct. If not, repeat steps 4 to 6 with the next code on the list.
If none of the codes work, or if you have any other issues, it's recommended to consult the user manual of your Magnavox CLO358 universal remote for additional instructions and a complete list of codes.
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • MAGNAVOX ZV427MG9 DVD Recorder / VCR Combo LINE-IN RECORDING (NO TUNER)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • 4helpful
    I have a Magnavox DVD Recorder/VCR ZV427MG9, but I don't have an instruction manual to go with it, at least on how to record from VHS to a DVD, could you tell me where, via internet I would be able to get...
    You can probably download the pdf of the manual for this model from the following site:
    http://tv.manualsonline.com/manuals/mfg/magnavox/zv427mg9.html
    The document should feature a picture of the unit. This is for the ZV427MG9 model ONLY.
    I hope this helps somewhat.
    1helpful
    Hello. I have a model # URC-4640Boo and am trying to set it up to work an a Sony dvd-vcr combo model # SLV-D300P and can't seem to find out how. Can you help me?
    Configuring codes:
    1.Turn on a desired device (VCR or DVD player)
    2. On the remote control, press a device key once (i.e., DVD/VCR,
    CBL/SAT or TV).
    NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
    To program control of a DVD Player,DVD Player/VCR
    Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
    To program control of a Cable Box, Cable Box/PVR (or DVR)
    Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
    Combo, press CBL/SAT once.
    3. Press and hold SET until the LED (red light) blinks twice,
    then release SET.
    4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
    the LED will blink twice.
    5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
    Auto Code Scan:
    1.On the remote control, press TV once.
    2. Press and hold SET until the LED (red light) blinks twice, then release SET.
    3. Enter 9 - 9 - 1.The LED will blink twice.
    4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
    5. To lock in the code, press and release SET.The LED will
    blink twice.
    6. To search for the codes of your other devices, repeat steps
    1 to 5, but substitute the appropriate device key for the device you are searching for.
    Thanx
    Need codes for Go.Video remote control
    Go video remote for dvd/vcr recorder combo; you program TV by 2 digit codes. press TV power down when TV is powered on; and input 11 for JVC TV, or 03 for GE TV. You can experiment any two digit codes until TV shut down, then you have just finished programing n150b remote. This also work for all LG dvd/vcr combo recorder remote such as 6711RN203A..
    I need the remote codes for an emerson dvd/vcr combo
    i need the exact brand and model of the remote.
    thanks
    tom
    31helpful
    6answers
    Remote control code for magnavox dvd/vcr combo
    I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
