20 Most Recent Emerson EWR20V4 DVD Recorder/VCR Questions & Answers
2answers
Dvd player wont play
Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
1/3/2020 2:45:58 AM • Emerson EWR20V4... • Answered on Jan 03, 2020
2answers
My emerson ewr20v4 plays cds with music but not dvd with movies. It keeps displaying disk error
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
1/2/2020 5:45:46 AM • Emerson EWR20V4... • Answered on Jan 02, 2020
2answers
Bought a new dvd it will not play, its giving me a
A regions code error means that the player is not compatible to play a DVD from a different region than what it was designed to play. For example, if you purchased your player in the U.S. or Canada then it is a region 1 player and therefore will play DVD's from region 1.
Here is a region map http://www.mvps.org/marksxp/WindowsXP/dvd/regions/regions.php
There are however, ways around this as some manufacturers of players have made a way to be able to allow the end user to unlock the software codecs that are for different regions. You will have to search for an online source that has a download or a procedure to follow to unlock your player.
12/5/2019 9:33:47 AM • Emerson EWR20V4... • Answered on Dec 05, 2019
3answers
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
8/17/2019 9:56:58 AM • Emerson EWR20V4... • Answered on Aug 17, 2019
Does Emerson EWR20V4 have a tuner built in?
No.
9/1/2015 4:57:00 AM • Emerson EWR20V4... • Answered on Sep 01, 2015
2answers
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
9/4/2014 8:53:30 PM • Emerson EWR20V4... • Answered on Sep 04, 2014
3answers
Emerson DVD Recorder EWR20V
The problem is likely that you are using 8x/2x media. Though the booklet does not say it, the burner does not support anything above 4x for DVD-R and 1x for DVD-RW. Calling their tech support can (possibly) get an update for this problem. Otherwise, the burner cannot use anything but outdated media.
8/14/2014 5:19:44 PM • Emerson EWR20V4... • Answered on Aug 14, 2014
2answers
How to transfer from dvr to dvd recorder?
A DVD recorder, not connected to a computer, only can record movies. If you have a DVD reorder connected to your PC, you need software, like NERO, to be able to write all the different codes needed to make a DVD a playable one for movie, audio or just files. (Data)
7/8/2014 8:36:53 PM • Emerson EWR20V4... • Answered on Jul 08, 2014
Can model number ewr20v4 record from vhs to dvd
Repeating my previous answer: I haven't been able to use my Emerson EWR20V4 for a long time, but as I recall, the easiest way is to cue the tape to your desired starting point, pause, then hit the record button on the panel's DVD side, let it spool up & start recording, then unpause the tape. If desired, I think you can hit the DVD record button again to set 1/2-hr. increments before the recording will stop.
7/8/2014 8:17:02 PM • Emerson EWR20V4... • Answered on Jul 08, 2014
Can i transfer vhs to dvd
7/8/2014 8:14:31 PM • Emerson EWR20V4... • Answered on Jul 08, 2014
0answers
2answers
How do you change the speed from sp to LP
Use the "REC SPEED" button right to the POWER button on the remote control.
5/9/2014 9:13:29 PM • Emerson EWR20V4... • Answered on May 09, 2014
2answers
Need to order remote control for Model EWR20V4
I have a brand new one I'll sell you right now for $25 [email protected]
4/26/2014 6:21:43 PM • Emerson EWR20V4... • Answered on Apr 26, 2014
Ripping video from home dvd emerson ewr20v4
I think aHi DVD Ripper can help you with this very well.
The DVD Ripper DVD Ripper that it has faster speed, higher quality and handier use, and we were fascinated by its attractive appearance, easier conversion and steady multifunction.
Why not get a free trial from official website?
http://www.ahisoft.com/ahi-dvd-ripper
Hope it can help you more or less!
3/20/2014 6:00:46 AM • Emerson EWR20V4... • Answered on Mar 20, 2014
3answers
Won't record and never has. get disk error e24
Anyone know where I could get a free download for a Emerson Dvd/vcr combo firmware upgrade??? (Ewr20v4) I need it right away . Emerson will charge to mail me one.
3/10/2014 3:05:49 AM • Emerson EWR20V4... • Answered on Mar 10, 2014
Emerson EWR20V4 DVD Recorder/VCR Logo
203 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
ewr20v5 dvd recording error
  • Televison & Video
