Acer Aspire One - had no problems but when tried to turn it on,goes from Acer Empowering People screen with F2 & F12 options for settings etc, and then to plain blue screen with Acer logo. Nothing seems to work - tried booting from HDD as first option but made no difference. I haven't downloaded anything to netbook at all.
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Have acer aspire one netbook that will not boot it only go to blue screen that say checking filr system on c
the type of file is fat32 and then it go back tring to reboot with the choice of starting normally or with safe mode and if i push safe mode no thing happens
