Camera is Pentax Optio 30
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
SOURCE: Need a driver for my pentax optio s45
Windows XP uses its own built-in drivers for digital cameras like your Optio 50. There is not driver for you to download.
With XP you should be able to simply open up the "My Computer" icon on your desktop.
Under "My Computer" you should see a "Removable Disk".
Double Click on it, and then your should see "DCIM", double click on that and then you will see "100PENTX".
Double click on "100PENTX" and you will see all your pictures.
You can then copy those pictures to anywhere on your computer.
If this does not work for you, you can always use a card reader to
download your pictures. Many later model computers have built-in SD
card readers. If your computer does not have a slot for an SD card you
can purchase a card reader, usually for under $20, at most major
computer/electronics equipment retailers.
SOURCE: Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
SOURCE: Pentax Optio MX4 won't read my new SDHC 4gb
Does the camera work with any other card? Was the card formatted in the camera? Some cards from some manufacturers just don't work in some cameras.
SOURCE: Pentax Optio S10 - Turning on problem
What kind of shape is your battery in?...old, been charged many times, needs charged, dirty contacts on the battery or inside the camera?
