20 Most Recent Pentax Optio S Digital Camera Questions & Answers
0answers
manual
Hi - I have a Pentax S6 with a 1 GM SIM card. I
The S6 works with SD cards. Your 4GB card is actually an SDHC card and will not work with your camera. You need to use SD cards, 2GB and smaller.
8/30/2012 3:43:10 AM • Pentax Optio S... • Answered on Aug 30, 2012
I get a message 'lens
Try the procedures in this tip.
8/30/2012 3:43:05 AM • Pentax Optio S... • Answered on Aug 30, 2012
Software Installation Problem on Mac OS X
You don't need to install anything.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
8/30/2012 3:39:57 AM • Pentax Optio S... • Answered on Aug 30, 2012
Pentax Optio A10
8/30/2012 3:38:48 AM • Pentax Optio S... • Answered on Aug 30, 2012
Pentaxoptioe50 cant copy pictures to computer is
Having gone over two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
9/20/2011 7:10:48 PM • Pentax Optio S... • Answered on Sep 20, 2011
Will not focus.
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. Also PULL the lens hood when it comes out , repeat till the lens moves freely , tap out any dirt or dust on the lens gap to free the movement.
Tips to open and check for common faults:
http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using Fixya
9/20/2011 12:35:36 PM • Pentax Optio S... • Answered on Sep 20, 2011
Need help with moving pictures
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
7/18/2011 11:56:16 AM • Pentax Optio S... • Answered on Jul 18, 2011
Optio ls1000 pentax - the lens cannot be opened it
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre as it canbe failure of the control/drive unit.
get estimate before you decide. It will be good to have it checked at the Pentax service as you do not have to run around for spares.
7/6/2011 4:56:52 AM • Pentax Optio S... • Answered on Jul 06, 2011
I have an Optio S
They are being saved to the internal memory of the camera. With no card in the camera, go into the menu and find "format" and follow the instructions to erase the internal memory. Insert your card and it should now work properly.
6/28/2011 4:09:29 AM • Pentax Optio S... • Answered on Jun 28, 2011
Hello heatman Hi. I have a
You cannot fix this problem. Contact the local dealer or customer service to have it repaired.
For your information -
A charge-coupled device (CCD) is a device for the movement of electrical charge, usually from within the device to an area where the charge can be manipulated, for example conversion into a digital value. CCD a major technology for digital imaging.
In a CCD device, the charge is actually transported across the chip and read at one corner of the array.
An analog-to-digital converter turns each pixel's value into a digital value. CCDs use a special manufacturing process to create the ability to transport charge across the chip without distortion.
This process leads to very high-quality sensors in terms of fidelity and light sensitivity. CCD sensors, as mentioned above, create high-quality, low-noise images. CCDs use a process that consumes lots of power. CCD sensors have been mass produced for a longer period of time, so they are more mature. They tend to have higher quality and more pixels.
6/10/2011 2:59:17 AM • Pentax Optio S... • Answered on Jun 10, 2011
3answers
A90
A- I have a Pentax Opio S hence I had to get the "fwdc110p.bin" file here:
http://www.badongo.com/file/707791
B- Drop this file on your SD Card at the root directory (same level as DCIM folder) or as described by the following link and then close your camera to OFF:
Attention: Do not load this file yet onto the camera i.e. the menu+power on procedure, follow step C first...
Important!!! Insert a fully charged battery or connect to an external power source.
C- Open the now infamous "Secret Menu" in order to re-initialize your camera prior to re-installing the new firm ware: Simultaneously press MENU + Flash symbol button + Power ON...a white screen with data written in black should show.
Then a sequence of buttons must be pressed: 2 times the focus button (flower, mountain, MF symbols button) followed by 2 toggles to the Right of the "OK" button...then press MENU once and voile...the Secret Menu appears!
Using the down toggle of the OK button, go to ROM UPDATE then go down to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Once this has been completed, turn your camera off.
D- Load the firm ware by opening your camera with the MENU+Power ON procedure...finally this should be posting "Complete" after the "Loading" message, instead of the "Error!" that we initially kept on having.
Your camera should be working perfectly! Only thing is that you will have to redo your personal settings on it from scratch...but hey, this is much better than to wait for months to get your camera back from Pentax and save that money for your next photogenic trip!
5/27/2011 1:52:01 PM • Pentax Optio S... • Answered on May 27, 2011
The battery charger indicator light
If it's an old battery that's been charged many times, then I would guess the battery is at fault. You can get an inexpensive replacement at bestbatt.com
3/15/2011 12:43:18 PM • Pentax Optio S... • Answered on Mar 15, 2011
How can i update my pentax optio s10? thanks!
If there are any firmware updates for your camera, you can download them from the support section of the Pentax website.
10/29/2010 1:53:53 AM • Pentax Optio S... • Answered on Oct 29, 2010
When I press the menu button I get a yellow
Hi
The SD Memory Card/MultiMediaCard is equipped with a write-protect switch. Setting the switch to [LOCK] protects the existing data by prohibiting recording of new data, deletion of existing data or formatting of the card.
Check your SD card to see if the lock switch has not be activated as this can cause you to be locked out of the menu on the camera.
Hope this helps. Please remember to rate my answer. Thanks.
7/25/2009 8:56:14 PM • Pentax Optio S... • Answered on Jul 25, 2009
How do i dowload to my computer i dont have a disk
use the provided usb cable (or purchase an after maket usb type 1 to usb 8pin AGOX connector)
Download usb drivers fromhttp://www.pentaximaging.com/files/scms_docs/opt_slg_usb.exe
6/9/2009 8:37:22 PM • Pentax Optio S... • Answered on Jun 09, 2009
Pentax Optio S Digital Camera Logo
49 questions posted
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
get message 39 lens
  • Cameras
