20 Most Recent Pentax Optio 430RS Digital Camera Questions & Answers
I have a Pentax Optio
Hello! Please check the manual: "Troubleshooting" or "Taking pictures" part. https://manualsbrain.com/en/manuals/1040023/?page=86
10/20/2017 8:28:32 AM • Pentax Optio... • Answered on Oct 20, 2017
Memory card error
Hi. It sounds like the pins are bent. Use a flashlight to see IG you can see them. If they are bent, try and use something flat to push back into place. If not you may have to send it in for service.
12/19/2014 1:19:30 PM • Pentax Optio... • Answered on Dec 19, 2014
Having gone over two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
8/17/2011 4:34:06 PM • Pentax Optio... • Answered on Aug 17, 2011
How to download to computer
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
8/16/2011 11:30:10 AM • Pentax Optio... • Answered on Aug 16, 2011
I cant upload my pics off fmy camra to my
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
6/29/2011 4:27:55 PM • Pentax Optio... • Answered on Jun 29, 2011
Need to upload and unable to find our Optio 430RS
Try NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
5/5/2011 5:22:42 PM • Pentax Optio... • Answered on May 05, 2011
2answers
It won't turn on even with a fully charged
yeah if you have had it for that long the batteries might be dead even if the appear to be charged i would get new batteries or get a new camera get one cheap on eBay ! have a good day :)
8/7/2010 12:23:44 AM • Pentax Optio... • Answered on Aug 07, 2010
A90 error code
I am looking john honest...JB
3/30/2010 7:47:30 PM • Pentax Optio... • Answered on Mar 30, 2010
My batteries keep going flat
Digital cameras EAT batteries. Buy only the best. If you don't mind paying a lot, use lithium batteries. They last longer but, the price doesn't actually make them a savings. They are only more convenient. If you have rechargeable, they lose their ability to accept a full charge after a while. Once they've been charged about 400 times, their life gets shorter each time you use them.
1/6/2010 3:17:36 PM • Pentax Optio... • Answered on Jan 06, 2010
How does the delay feature work? I would like to
Hello
Thank you for using FixYa for your problem
set the self timer to on, press the button to take the photo and a red light on front come on, run around into position as you have 10sec's
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
12/3/2009 8:39:40 AM • Pentax Optio... • Answered on Dec 03, 2009
Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
http://www.upgradecomputermemory.com/ram.cfm//memory/P/Pentax/Pentax-Optio-430/
Optio 430 RS
http://www.upgradecomputermemory.com/ram.cfm/memory/P/Pentax/Pentax-Optio-430RS/
6/10/2009 12:57:21 PM • Pentax Optio... • Answered on Jun 10, 2009
2answers
Pentax optio 430.
the focus assembly is not working . will have to replace lens assembly to make work correctly .
5/23/2009 10:58:38 PM • Pentax Optio... • Answered on May 23, 2009
All my pictures are comming out over exposed!
CCD FAILURE!
Call Pentax for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
5/23/2009 8:51:17 PM • Pentax Optio... • Answered on May 23, 2009
How to download picture in my computer from my pentax optio 430
DID IT COME W/ A DC TO DOWNLOAD ON YOUR COMPUTER, SOMETINES THATS THE KINK TO DOWN LOADING PICS TO COMPUTER WHRN CD
IS DOWNLADED
4/26/2009 7:20:54 AM • Pentax Optio... • Answered on Apr 26, 2009
3answers
Error A90
The a90 error message, relates to an electronic fault on the main printed circuit board of the camera.
9/11/2008 6:56:07 AM • Pentax Optio... • Answered on Sep 11, 2008
Digital Camera Lens Problem
Read someone had the same/similar problem. Lens sensor at fault or broken. Camera not really worth the expense of a repair.
5/10/2008 2:16:15 PM • Pentax Optio... • Answered on May 10, 2008
My Optio won't stay powered on.
This is probably due to a broken sensor tab inside the lens, or a failed sensor. When the lens reaches the end of its travel a small plastic tab will pass between the ends of a C shaped sensor and let the camera know the lens has reached the end of its travel. You are not hearing a safety device, you are hearing the gears actually slipping. Don't let it do that too much or you will turn one problem into two problems quite quickly. If you cant find the broken part it will require professional repair. I would advise against taking the lens assembly apart. They are extremely hard to get back together and you very well may end up with a junk camera. David Millier Advance Camera Repair
2/24/2007 3:32:47 AM • Pentax Optio... • Answered on Feb 24, 2007
Pentax Optio 430RS Digital Camera Logo
Popular Tags
23 questions posted
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
memory card error 4 gb cf cards 80x
  • Cameras
