SOURCE: want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
SOURCE: Toshiba Satellite a215-s7437 will not boot at all - black screen
It sounds like two possible things. One thing may be that your screen is not working anymore. Can you get a monitor and plug it into your port located on the side of your laptop? If your screen pops up on the monitor this tells us your screen is either in need of replacement or a connection may be loose.
If that is not the case......
Another thing is your hard drive may not be initiating. If you feel confident enough I would open the back where the hard drive is located and make sure the hard drive is not loose. Does it give you any beeping sounds when you turn it on? Can you count the number of beeps? This will tell you what the problem is on boot up. Also, is it a black screen with a cursor blinking?
SOURCE: Toshiba satellite a55 s1063, driver wireless
OK guys here is the wireless driver for Toshiba satellite a55 s1063. It took two weeks for me to find this driver.
http://www.wireless-driver.com/download/atheros/Atheros-based-all-wireless-cards.htm
SOURCE: Toshiba Satellite Goes completley off! Black screen, NO POWER!
This problem is likely caused by overheating. The CPU reaches a temp to high and shuts the system down. When you try to turn it on the system is still to hot and it will not let the computer power on. You can try blowing out the fans and heat sink with an air compressor or can of compressed air. If this does not help the problem you may need to have thermal compound reapplied. If that does not fix it it will need a new heatsink/fan/
SOURCE: Toshiba Satellite A105-S4384 PC Notebook Drivers
All drivers for your machine can be downloaded from the link below.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1495919&rpn=PSAA8U&modelFilter=A105-S4384&selCategory=3&selFamily=1073768663
Robert from Blitware
I hope this helps.
If this Answer goes some way towards helping to resolve
your Query, Problem or Fault, please take the time to Rate it. Doing so helps
Solution Providers, like me, better understand the needs and the point of view
of Askers, like you, and guides us in exploring the best ways to provide the
most comprehensive, useful and high quality Responses and Solutions we can. If
you need further help, please do not hesitate to post another Question or add a
Comment to this Question.
Thanks for using FixYa.
Is there another user already set up on the computer? If not that might be the problem.
