20 Most Recent Toshiba Satellite A505 Notebook Questions & Answers
Did the CD jam/float around inside the laptop?
Toshiba... | Answered on Feb 15, 2013
2 points to understand. 1) if you pop open your laptop, the warranty is void. That said, 2)remember that in a laptop, it is VERY tight. So, once the screws are off, there will not be alot of room to work. All of the wires and connections are very short so pulling the case totally off is not an option. Be patient and take your time and you should have no problem finding and pushing the usb port back to it's correct position. Pay close attention as there are all kinds of little parts you do not want to pop out and have to figure out where they go back too.
Toshiba... | Answered on Sep 26, 2012
Bea,
Not sure what you intend to do by saying you want to format the laptop. If you mean that you want to restore the laptop to 'out of box' condition, or as new, then you must look for one of two things:
- If, while in Windows, you click Start, then All Programs, and locate a listing for Toshiba, then look inside that category for an application to rebuild, or otherwise restore the laptop to the as new condition.
... or ...
- When you first power on the laptop, usually you see on the first screen an option for SETUP, like Hit F2 for Setup, or Hit F10 for BIOS, etc. There may be one specifically for getting into the Toshiba Rebuild routine.
Most recent laptops have a hidden partition, which contains all the files that are used to produce a brand new condition for your laptop.
Sometimes there are two options, one to wipe everything and rebuild, and one to actually protect your documents, but not any added later applications, while it rebuilds it.
Those are the things to look for. Be careful and be certain what it is you wish to do to it, before you do it. Most of those options, when you find them, are not reversible.
If there is something that you did recently that you want to undo, you might be able to accomplish that if your laptop is set to retain System Restore information every few days, or before major upgrades, and you can restore to the day before whatever it is you might have done that is making it run strangely now.
Cheers!
-a.
Toshiba... | Answered on Jun 24, 2012
jst see control panel usb setting or ur power scheme setings
Toshiba... | Answered on Mar 24, 2012
Most likely replace the hard drive if it cant format the drives bad
Toshiba... | Answered on Aug 23, 2011
This issue requires intricate soldering, you need to send it to Toshiba for motherboard replacement. Most likely, the USB ports were pushed in too hard and the port broke off of its location. Even if you were able to access them, it is unlikely you could fix. However, this model is still fairly new, so send it to them and claim it came that way...
Toshiba... | Answered on Aug 09, 2011
Hello geniet1:
If the USB ports are loose, then the computer is going to have to be disassembled for repair.You should have Toshiba, or a Toshiba authorized service center fix it. If I remember correctly,all you have to do with Toshiba laptops is just drop them off at UPS for repair.UPS sends them to Toshiba for free, and Toshiba returns the repaired laptop to you.
Toshiba... | Answered on Apr 06, 2011
I would say that was too long and there is a problem somewhere. I would run CHKDSK/F straight away to clear any disk errors and try again.
Hope that helps.
Toshiba... | Answered on Feb 24, 2011
You should remove the batteries to see if it will power up and start using the AC adapter, it does not need the batteries to run when it is on an AC adapter. It may have bad connection at the DC input jack assembly.
Post back.
www.insidemylaptop.com
Toshiba... | Answered on Dec 30, 2010
Restore the system first.http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If the problem is same change the mouse.
Follow the bellow link just click on.
After change the mouse if you will face in same look because virus affected.
http://www.fixya.com/support/t7439427-seems_put_anything_echo_ze
You will just download boo-table f-secure disk, http://www.askvg.com/download-free-bootable-rescue-cds-from-kaspersky-bitdefender-avira-f-secure-and-others/ and write cd ISO file and scan at boot time .
Hope it will help you.
Toshiba... | Answered on Dec 29, 2010
Im having the same problem it happened out of nowhere.
We ran a typical Satellite A200 battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
Toshiba... | Answered on Nov 24, 2010
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Toshiba... | Answered on Dec 05, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on Sep 25, 2019
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Toshiba... | Answered on Sep 12, 2019
Toshiba Satellite A505 Notebook Logo
24 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
two usb ports
  • Computers & Internet
