SOURCE: coffeemaker will not brew a full pot
Try cleaning it with pure vinegar. 3-4 times just keep running it through the machine.
SOURCE: Keurig shuts off as water heats and as coffee is brewing?
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
SOURCE: I set the brew size on the Keurig, but can't
the blinking blue lights, means the water level is low...BUT sometimes it sticks, if the tank is not clean..its that round disk, on the side of the water tanks that sticks..try resetting the tank..set set the default brew size..goto menu, then goto brewsize to set the default size...when it says ready to brew..then you can select the size...
SOURCE: Keurig Model 831 one-cup brewer
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
SOURCE: Keurig B66 model - "Not Ready" message when I push
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101-=-=-
