SOURCE: need to replace pulley for serpentine belt on a 2000 Eclipse
left need to use a air tool most likely
SOURCE: is the crankshaft pulley aright or left handed thread
The bolt in the middle is usually counterclockwise. Standard thread removal.
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
SOURCE: 1992 nissan maxima timing belt replacement
need to take off almost every thing from the front of the motor. then take off top half of timing cover.
pull the harmonic balance pully off. then the bottom half of the cover will come off. becareful
the cam gears are hard to aline.
do you no where the knock sencor is located?
if so please email me @ [email protected]
SOURCE: How do I replace the belt tensioner pulley on my
You don't need to remove any parts.
Locate the belt tensioner and attach a wrench to the boss provided. Typically, you rotate the tensioner so the pulley moves away from the belt. You may find it will take several tries to position the wrench, or get the correct wrench so that you can rotate the tensioner sufficiently to remove the belt.
Install new belt in reverse order.
