20 Most Recent John Deere D140 48 in. 22 HP Front-Engine Riding Mower Questions & Answers
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
John Deere D140... | Answered on Apr 15, 2018
https://www.bobcatmanualonline.com/downloads/john-deere-chainsaws-cs36-cs40-cs46-cs52-cs56-cs62-cs71-cs81-service-repair-manual
https://www.green-parts-direct.com/john-deere-parts-diagrams/john-deere-cs36-cs36le-cs40-cs40le-cs46-cs52-cs56-cs62-cs71-cs81-chain-saws-pc2847-carburetor-air-filter-cs46/AD-4275-34517-432112
John Deere... | Answered on Jan 16, 2020
Black smoke means iots getting too much fuel. This would cause lack of power as well. Check your choke as well as your carburetor.
John Deere... | Answered on Jan 12, 2020
http://www.reliancepowerparts.com/catalog/documents/tech-tips/torque-and-rebuild-specs/tr-jd-6068-PT-TSI.pdf
John Deere... | Answered on Jan 11, 2020
Multiple fuel filters. One inside tank and an external. Check fuel flow and volume (pressure) at the injectors.
John Deere... | Answered on Dec 31, 2019
If its an over head cam engine then yes you would have to do the valve timing, if its a push rod engine then no you do not.
John Deere... | Answered on Dec 24, 2019
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
John Deere... | Answered on Dec 22, 2019
I'm working on z225 now the fuel pump gets the its vacuum from the crank case for it to pump gas these have a crank case breath hose under the mag to keep it from building up pressure let's the motor breath if this is stopped up it will pull the air it needs through the valve breath hose that runs to the crab while letting the mother breath its not as big as the crank case breathing hose and builds up pressure and pushes oil into the fuel pump pull the crank case hose off and check for oil if thiers oil in it check under the mag fine dirt grass gets under their i hope this helps
John Deere... | Answered on Dec 14, 2019
1945: 542700
1946: 555334
Tractordata.com
Shows year of mfg as 1945.
John Deere... | Answered on Dec 02, 2019
The oil inside for the reverser is good? You found that the oil level was correct, the fluid was clean and no further actions were needed? Usually the failure is the clutch pack but that is seen in the fluid. Can you feel or notice that the shift lever is moving into the gear selection correctly? Do you notice, feel or hear that reverse gear is engaged when selected. Do you hear any noises or sounds that weren't there before the failure? Did this failure happen out of the blue or have you noticed reverse acting up for a while now? Please let me know. Good luck.
Order the service manual from John Deere.
John Deere... | Answered on Nov 30, 2019
Request the diagram from John Deere.
John Deere D140 48 in. 22 HP Front-Engine Riding Mower Logo
Popular Tags
3 questions posted
Top John Deere Garden Experts
Joseph Mueller
Joseph Mueller
john h
rjivaro
Are you a John Deere Garden Expert? Answer questions, earn points and help others
View Most Popular
John Deere Garden
  • John Deere Garden
Most Popular Question
adjust tension belt john deere ride d140
  • Garden
