SOURCE: Control panel lights OK; Won't start into cycles
Hey, just had the same problem with my 9150. Moisture got into the electronic key pad. $300 to replace it. I was 5 months out of warranty.
I called 800-688-9900 and Maytag agreed to cover the part and we have to cover the labor. Not completely satisfied but a little bit helps.
SOURCE: subaru loyale wagon replacing the timing belt
Get a proper manual like Haynes (amazon, parts store, Haynes.com). You should not have to take either main pullel or cam pulley off to change timeing belt, you DO want a new tensioner and and new idler pulley (if there is one). Failure to replace these may result in a later failure that wipes out the blet, and possibly the motor (if it is an interference motor).
If you can change the oil pump from working on the front side of the motor, you are either a magician or a contortionist;!) and I need you to help me work on my car;~) It's pretty rare for an oil pump to go bad before 400K km or 300K miles ... the bloddy things are in a constant bath of oil!
SOURCE: High oil Consumption, BMW M5
Look for Castrol TWS 10W60 Motor Oil. This car should not burn so much oil, you need to use a different kind. It is recommended by BMW as well. I also heard the VANOS isnt an issue anymore, can be fixed with a different MAFF. Good luck!
SOURCE: maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
