Susan Nunn Hurtick Posted on Nov 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an SA-AK20 Panosonic Stereo System. When I turn it on sometimes it plays for 20 secs and shuts off F61. Other times it will play for an hour or sometimes 5 hours..Shuts off on it's own.
Leroy Elliott
Level 3:
Fixya-Fanatic:
Visited the website for 90 consecutive days.
  • Master 425 Answers
  • Posted on Dec 06, 2019
Leroy Elliott
Master
Level 3:
Fixya-Fanatic:
Answers
425
Questions
0
Helped
137238
Points
1154
Check for a clogged cooling fan
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Mar 27, 2008
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
CHANGE STK --------IC
A
Anonymous
  • Posted on May 06, 2008
SOURCE: SA-HT680 F61 Error
FIX IT!! =]
nuwan chinth
nuwan chinthaka
  • 111 Answers
  • Posted on Jan 15, 2009
SOURCE: panasonic sa-ak25
the problem is F61 is speaker protection mode on.
fault with your audio power amp section.
i can help you.
nuwan.
Anonymous
  • Posted on Jul 17, 2009
SOURCE: television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Anonymous
  • 189 Answers
  • Posted on May 12, 2010
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Panasonic SA UX100 f61 code error
F61 is a secondary power supply issue causing the mechanics to jam up or the CD mechanism has jammed causing this message.
F61 error message panasonic sa ak410
try cleaning out the fan and make sure it spins freely. If the unit detects that the fan isn't spinning it will shut off.
Panasonic error f61
If you do not know what an audio output IC is, what would ordering one do for you? And unless you have the know how and special gear there is no freaking way you could ever replace it.
Either have someone repair it for you or go shopping.
5helpful
2answers
6helpful
2answers
HELLO
3helpful
3answers
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
2answers
SA-HT680 F61 Error
Typically the F61 error is a protection error indicating that there is a problem with the output amplifier section. The failiing part is usually IC501 (part number RSN311W64D) which costs about $95. Have this unit checked as there are other possibilities.
Dan
2helpful
2answers
Nide code fore a panasonic cd stereo sistem
Most likely the regulator IC is defective. Part # C5BA00000105.
System keeps shutting down
Code F61 can point to trouble in the audio output ic chip, are the loudspeakers connected correctly no short circuits.Also check that the cooling fan operates.
 Grubhead
Grubhead
SmartAviator
SmartAviator
