Panasonic Audio Players & Recorders • Uploaded on Oct 13, 2013
F61 Error Solution for the
Panasonic SC-AK600 CD Shelf System - if you have any knowledge on electonic just replace the electronic part number #C5ZAZ0000075
you can buy it directly from Panasonic,,, or if you dont have any knowledge on electronic just bring it to nearest panasonic service center.
if this help you please rate me thanks bro...
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
36 questions posted
491 Questions
91 Questions
82 Questions
74 Questions
53 Questions
