I have working and fully max upgraded xw4600 , sister to yours.
MBR is limited to 2GB,(approx)
the OS must be 64bit, to go GPT,
are you saying to boot from this drive, full system not told
I run SSD as boot drive, 128GB. then drive 2 non boot can be any thing I want in w10 64bit, nobody uses w7, now, it dies, Q1, 2020.
UEFI safe boot needs, OS RELOADED, and to GPT.
and 64bit OS, it is NOT a BIOS issue. but do upgrade BIOS,
UEFI does not own GPT, you can run legacy with GPT, microsoft.com has full pages telling you how to do that.
I have w10 64bit, v1903 on mine. now. runs like champ.
once booted the OS runs the HDD not BIOS, a fact.
when you fresh load w10 64 from ISO the OS installer will set that 3TB as GPT , regardless of BIOS.
try it see.
but SSD drive there booting is always best. even on all my servers.HP and DELL.
you can set up w10 to put all data on drive, E: 3TB
or have 2 partitions there, programfiles and DATA.
then OS owns the SSD, alone.
hope that helps some.
SOURCE: cannot install new hard drive on HP xw4400 Workstation
Check the to see if its in master or slave configuration.Also a great boot tool is Hiren's BootCD and here the link below.If you a tech to call you for a step by step help go to our website and the that link is below as well and take care.
http://www.hirensbootcd.org/download/
http://www.ezsystemrepairs.com/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
SOURCE: I'm having problems installing Ubuntu on Windows 8.
restart the computer HOLD the keys CTRL+F11 OR F12 depend of your model, and restore to the factory defaulty, and try it again.
God bless you
