Refrigerators Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridge and freezer not cooling. The fan is running
Whirlpool fridge and freezer not cooling. The fan is running and the back was very dusty, cleaned the back and underneath, still at 55 degrees. Any suggestions?
  • Mike McWhinney May 11, 2010
    Check the controls for the refrigerator/freezer. Turn them to a cooler setting and recheck the temperature. Also make sure the back wall of the freezer does not have an ice build up on the back wall.
    Is the compressor running?
Anonymous
Level 3:
President:
  • Master 1,187 Answers
  • Posted on Sep 17, 2009
Anonymous
Master
Level 3:
President:
Answers
1187
Questions
0
Helped
528371
Points
4102
Is the compressor clicking? If so, the pressure may be too high. tHis happens if the temperature control is lowered too soon after the compressor cuts off, or if house power fails for a shorrt period, etc.
1. UNPLUG the power cord.
2. Set the temperature dial to the settings you want.
3. Close doors and wait a full 10 minutes (more if you don't get impatient).
4. After 10 full minutes, plug power cord back in. It should start now.
5. Try not to open fridge for an hour or so, or until you hear tyhe compressor cycle off.
Hope this hellps!
1helpful
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
1helpful
Whirlpool side by side not cooling
The round object is the compressor. Is it running continuously, or is it clicking on and off every 2 or 3 minutes? There also should be a fan beside compressor. Is it running? Also check Fan in freezer to see if it is running. Is there any frost build up on inside back freezer wall? If fans are working and compressor is running continuously and there is no frost buildup in freezer, then you most likely have a sealed system problem meaning its low on freon or there is a blockage in system.
2answers
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
2helpful
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Not cooling or cold
The REFRIGERATOR WAS MOVED TO ANOTHER SITE. AND IT HAS NOT GOTTEN COLD SINCE MOVE, PLUB UP 2 DAYS AGO. iT WAS UNPLUG AND CLEAN 2 DAYS BEFORE MOVE. COULD IT NEED ANTI-FREEZE?
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
