GE GSH25JFR Side by Side Refrigerator Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE Arctica intermittant clicking sound, panel flashes "hrs"
3 year old side-by-side Arctica (PS123NCRD) compresser stops, clicking sound begins, and display shows HRS instead of temp. Normal operation resumes after 15-20 min, but reoccurs 2-3 times per day.
Anonymous
Level 3:
  • GE Master 1,606 Answers
  • Posted on Sep 16, 2009
Anonymous
GE Master
Level 3:
Answers
1606
Questions
Helped
570377
Points
5623
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
1helpful
Have a GE Profile Arctica that is a few years old. It is "clicking" every couple seconds, like turning off and on constantly. I have been gone for a week if that matters. The HRS light is...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
4helpful
GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
3helpful
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Power is on but no control indicators are visible and the letters HRS are flashing inside one of the indicators inside the door. The refrigerator model is a pss26ng GE Profile Arctica
Unplug this refrig from the wall, let sit for one hour, then plug back in, if it starts then you may have a start device on compressor that is bad, more than likely it won't, normally the HRS means there is a "main board" problem. Main board is located on rear of refrig.
Fan in freezer under ice maker won't stop running.
Hi yes the fan blade could be hitting the shield or ice, remove the fan cover & check
GE Profile Arctica Icemaker
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
MY GE FRIDGE HAS STOPPED
This sounds like a compressor problem. At three years old it would be covered by warranty. Call for service.
1helpful
Top Refrigerators Experts
vince
Johnny 1000
