SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
SOURCE: can i use panasonic SB-AK57 speaker (6 ohm) with
yes only that the current will be less on the load.
no problem you can use .
also consider the watts of the speaker and the amplifier dont forget. the speaker should have more watts rated than amplifier output watts
SOURCE: Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Testimonial: "great feedback. "
