I don't have a descaling funnel as far as I can tell. Can the system be descaled without one or where do I get one?
DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinegar. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinegar and run through machine as if making coffee. Repeat this process several times using fresh vinegar until it comes out clear. Do this once a week and your maker will work much better.
Use citric acid or LEMON JUICE CONCENTRATE instead of vinegar. It cleans just as well but doesn't leave the funky odor that vinegar does. You can run enough water to get rid of the vinegar taste, but the odor will linger for days or weeks. Much better to use lemon juice concentrate (no pulp!!) or one of the commercial products like the one available from Starbucks.
