The use of a cooling base effectively supports the usual routine maintenance operations of the appliance, such as cleaning the chassis with a small brush and introducing compressed air into the air vents.
SOURCE: white smoke from air vents
Could be an incorrect refrigerant charge or defective pressure switch causing the evaporator to freeze and the air flow over it is causing the ice to melt and the resulting white smoke is condensation
Try resetting the purge counter:
1) Enter machine maintenance mode (on MFC240C all fourphoto/copy/fax/scan lights flash in maintenance mode). Care is neededin maintenance mode, otherwise critical settings may be inadvertentlycorrupted.
FAX models with numerical keypads:Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if youfail to complete the correct key sequence within two seconds, press theStop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys.Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenancemode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the loginformation list to reach the purge counter. The purge counter is the25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
SOURCE: "Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge
counter is already full. Please refer below for the instructions on troubleshooting
your machine.
1. To enter MAINTENANCE Mode: Press
MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the
following:
a. 8 then
press SET
b. 0 then
press SET
3. Using MONO START, just press it until
the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the
following:
a. 2 then
press SET
b. 7 then
press SET
a. 8 then
press SET
b. 3 then
press SET
This is to reset the purge
counter. Then press stop/exit
5. Using arrow up button look for the
following:
a. 0 then
press SET
b. 1 then
press SET (To reset unit)
a. 9 then
press SET
b. 9 then
press SET (To exit Maintenance mode)
SOURCE: clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1.
press buttons Set, Menu, Mono Start one by one, followed by up arrow
key four times. this should all be done as short a time as possible,
around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
